Same? USDM and JDM wiring harness!
Old May 16, 2002 | 01:08 PM
g's integ's Avatar
Default Same? USDM and JDM wiring harness!
Are they both the same and will a JDM harness work w/ USDM motor?
Old May 16, 2002 | 01:18 PM
sgT's Avatar
sgT
Default Re: Same? USDM and JDM wiring harness! (g'sinteg)
they are backwards, all the main plugs are on the opposite sides.
so no, they will not work in a left hadn drive car
Old May 16, 2002 | 01:19 PM
CivicEx95's Avatar
JDM harnesses are made for RHD cars. So the battery terminal connector will be on the drivers side of the engine bay instead of the passenger. Use your existing harness or get a USDM one if you're doing a swap.
Old May 16, 2002 | 01:20 PM
Katman's Avatar
Yes, the JDM harness WILL work on a US motor if it's in a RHD chassis. But if you're wanting to know if a JDM harness will plug and play into a US LHD honda, no it wont, not with out modification, which isn't worth doing. You're way better off with a US engine harness for a US car. The JDM harness is only useful for spare plugs & wiring on a US car.
Old May 16, 2002 | 01:25 PM
g's integ's Avatar
Default Re: Same? USDM and JDM wiring harness! (Katman)
thanks guys
Old May 16, 2002 | 04:16 PM
Zeus Zore's Avatar
well i toke a JDM wire and turn it around !! toke some work but now it is like honda made it !!! only i didt it wth a frined !! ;-) the bad part off it was engine wire, had 2 make one our self from old and the JDM, and some plugs was not in same place in the jacks !! speedo didt not work after a little shifting around the wires as well for the gas pump and control arms !! brun the rear washer control arm !!
Jimmii
Apr 9, 2009 06:54 PM
eddiecut
Aug 17, 2003 07:39 PM
Sukebei Oni
Jun 11, 2003 05:25 PM
Slopoke
Jun 19, 2002 11:07 AM
