I know its been covered: Fuel Cut Off Switch
Old May 16, 2002 | 01:02 PM
Lynx's Avatar
Default I know its been covered: Fuel Cut Off Switch
Can somebody email me directions to a fuel cut off switch. Friend of mine wants to have one installed on his Civic and I figure it is good to practice on somebody else's car.
Email: dr_evian@yahoo.com
Thanks
Old May 16, 2002 | 01:06 PM
zijiejijeijrkjk's Avatar
Default Re: I know its been covered: Fuel Cut Off Switch (Lynx)
get to the fuel pump. open up the tape that surrounds the wires. Cut the yellow and link it through there.
Old May 16, 2002 | 01:08 PM
Lynx's Avatar
Default Re: I know its been covered: Fuel Cut Off Switch (chomp_on_this)
Yeah, that seems simple enough, but I thought there was more involved as far as grounding it properly and attaching a relay.
Old May 16, 2002 | 01:09 PM
no, go to radioshack. buy a 2 dollar automotive switch. and use that. no grounds, no relays. you DONT cut the ground, ONLY the yellow wire. I have done this with three cars and no complaints.
Old May 16, 2002 | 02:24 PM
bus stop's Avatar
I thought I need to use a switch that can "match" the fuel pump electricial system...someone told me that the switch may blow if it's overload then no fuel supply when you driving.
Old May 16, 2002 | 02:26 PM
Default Re: I know its been covered: Fuel Cut Off Switch (WhosITR)
25 amps is fine. thats the only one they had. used it in three cars.
Old May 16, 2002 | 05:17 PM
tjtruong's Avatar
New User
remember its the bigger one of the yellow wire.. I believe there are two yellows
tj
socalrex88
Audio / Security / Video
Mar 2, 2008 01:50 PM
GSR-TRBO-DA
Jul 10, 2007 06:46 AM
RUBZERK
Aug 18, 2004 08:45 AM
itsJDMyo
16
Jul 20, 2004 06:25 AM
PrOjEkT ED9
Sep 4, 2002 10:23 AM
