Door Panel
Old Jan 24, 2007 | 08:43 AM
bbhockey19's Avatar
Default Door Panel
How do i take off my passenger side door panel on my 2000 si
Old Jan 24, 2007 | 08:48 AM
mikeycivic's Avatar
Default Re: Door Panel (bbhockey19)
you unscrew the screws that hold the plastic peices in and pull it off. There are little plastic clips in the back of it the clip into the door. Pull hard enough and they will come right off!!
Old Jan 24, 2007 | 08:50 AM
bbhockey19's Avatar
Default Re: Door Panel (mikeycivic)
what screws just on the door handle and in the coin tray/ armrest also if i ripp it out wount the plastic things break...
Old Jan 24, 2007 | 08:51 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Power windows and doors? There are most likely screws holding the power switches to the actual door panel. You'll have to remove those screw(s) and any other screws on the door. Search the little cup thing in the arm rest [if there is one] for a screw. There should also be a screw that you can see if you open the handle on the inside and look behind it.
After all the screws are removed [I can't imagine it will be more than 3-5 screws], the door panel pops off. There are little tabs that hold the door on, but they release and pop back on pretty easily.
Old Jan 24, 2007 | 08:53 AM
bbhockey19's Avatar
Default Re: Door Panel (Hatchy-Ownzjo0)
i found 2 screws one in the arm area and where the handle is where are the other ones..
Old Jan 24, 2007 | 09:07 AM
seabass10369's Avatar
there should be three screws under the speaker grille as well
Old Jan 24, 2007 | 09:29 AM
J9D6M's Avatar
Default Re: Door Panel (seabass10369)
There is one screw where the power window switch is, one where the door handle is, and 3 underneath the speaker cover. Once these are all removed, start at teh bottom of the panel and the clips will snap out. Also, lift the panel up once the clips are out beings the top of the panel sits down in where the window is.
Nuts
Honda S2000
Aug 7, 2008 06:32 PM
todd.ludwig
May 1, 2006 02:27 AM
206civic
Jan 8, 2005 11:43 AM
NtegraRacR05
Sep 15, 2003 06:57 PM
teg95
May 22, 2002 01:16 PM
