Looking for JDM Headlight Part Numbers
Old Jan 24, 2007 | 12:47 AM
coolhandluke's Avatar
Default Looking for JDM Headlight Part Numbers
I am in the process of finishing up my JDM Front install, but I have run into some snags since my front end is missing some pieces. I have shopped at my local Advanced/AutoZone and didn't have any luck finding an alternative solution for either of these parts. If I can get the Honda Part Numbers my friends at Honda can do the rest, I would appreciate any help on finding these pieces, or an acceptable replacement.
Square Brown Headlight Harness:
Cornerlight/Blinker Harness Plug:
Different Angle:
Thanks again.
Old Jan 24, 2007 | 04:14 AM
teg01type-r's Avatar
Default Re: Looking for JDM Headlight Part Numbers (coolhandluke)
Are you looking for the clip or just a way to make your lights work???
Old Jan 24, 2007 | 04:27 AM
DjMigs's Avatar
not sure if the pics of clips to the headlight you need but if that the case i do have them but the wire are cut close all you would have to do is add wire to it....again if thats want your looking for....if not passwordjdm sells harnesses you might want to give them a call plus they order parts from japan of honda....again this is what you may or may not be looking for as far as part numbers i can't help you out....
gl
Old Jan 24, 2007 | 04:58 AM
Default Re: Looking for JDM Headlight Part Numbers (teg01type-r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg01type-r &raquo;</TD></TR><TR><TD CLASS="quote">Are you looking for the clip or just a way to make your lights work???</TD></TR></TABLE>
I would prefer to just get the part number so I can order the piece. This way everything will have factory plug and play capability. If not the part number, then a piece I can buy that will sever the same function.
Old Jan 24, 2007 | 06:06 AM
Default Re: (DjMigs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DjMigs &raquo;</TD></TR><TR><TD CLASS="quote">not sure if the pics of clips to the headlight you need but if that the case i do have them but the wire are cut close all you would have to do is add wire to it....again if thats want your looking for....if not passwordjdm sells harnesses you might want to give them a call plus they order parts from japan of honda....again this is what you may or may not be looking for as far as part numbers i can't help you out....
gl</TD></TR></TABLE> like he said Password is probably going to be your best bet on finding a harness, other wise someone on H-T will have it laying around.
Old Jan 24, 2007 | 08:12 AM
mrnicolas's Avatar
password has those headlight plugs for $29.99 http://www.passwordjdm.com/pro...D=377
Old Jan 24, 2007 | 09:09 AM
Default Re: (mrnicolas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrnicolas &raquo;</TD></TR><TR><TD CLASS="quote">password has those headlight plugs for $29.99 http://www.passwordjdm.com/pro...D=377</TD></TR></TABLE>
I appreciate the link, but i have had two bad and really bad experiences with password in the past and will do what I can to avoid dealing with them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg01type-r &raquo;</TD></TR><TR><TD CLASS="quote">...other wise someone on H-T will have it laying around.</TD></TR></TABLE>
This is who I am looking for! *Unless I can get the part numbers
Old Jan 24, 2007 | 12:33 PM
cltitus's Avatar
part numbers are for JDM honda integra local honda/acura shops wont have them.
Old Jan 24, 2007 | 02:23 PM
DjMigs's Avatar
another spots might have them but you need to contact them for sure is
jdmland
hmomotorsport
i have those clips but they dont have wire you have to add to it....pm if interested
Old Jan 24, 2007 | 03:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DjMigs &raquo;</TD></TR><TR><TD CLASS="quote">another spots might have them but you need to contact them for sure is
jdmland
hmomotorsport
i have those clips but they dont have wire you have to add to it....pm if interested</TD></TR></TABLE>
Thanks, I have already emailed both of those sites and I am awaiting their replies.
Also, I have sent you a pm. Thanks
Nikademo
Oct 11, 2010 01:21 PM
SRd240sx
Audio / Security / Video
Jul 2, 2009 11:32 AM
FusionITR
Jan 26, 2002 11:18 AM
