broke bolt in my exhaust housing help!!!
K well while i was trying my new **** on see if everything fits i broke a bolt into my turbo exhaust housing.
you think it will still be ok if i dont put any bolts there ? or should i drill it let me know what you think.
here:
here:
Weld a vband fitting right to the housing and weld a plate over the internal WG opening. Did that on mine to just avoid dealing with the broken studs on the turbine housing.
3inch should fit perfectly, just cut the other studs down and weld away.
Worked great btw.
Worked great btw.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by legendboy »</TD></TR><TR><TD CLASS="quote">if you drill and tap with the right size tools, and hit it dead center you can take out all the bolt material without damaging/changing the original threads</TD></TR></TABLE>
tap what?
drill a hole in the center of the broken stud and use an appropriate size easy out.
tap what?
dont make this any harder than it is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 »</TD></TR><TR><TD CLASS="quote">drill and use an easy out</TD></TR></TABLE>
I have the same exhaust housing and one of mine broke off too, but its was one of the ones away from the turbine. Mine doesn't leak, but since yours is one of the main 3 it might.
Since it's off the car right now I would get that broke bolt out.
If you have a welder you can tack a little piece of metal to it and turn it out.
If there is any amount of the bolt sticking up out of the hole...You could just cut a slot into it with some kind of cut off wheel and use a flathead screwdriver to get it out...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shmaa »</TD></TR><TR><TD CLASS="quote">I have the same exhaust housing and one of mine broke off too, </TD></TR></TABLE>
x3 on that....
easy out didn't work so i had to drill it out and retap the hole. i used the same tap as the original threads so everything came out good.
x3 on that....
BlueSi2k
Mar 31, 2004 01:56 PM
k ill try to drill it then if it dosent work ill get one welded there or somethin
