H22 Intake Manifold Removal
Old Jan 23, 2007 | 08:48 PM
h22sedan's Avatar
Default H22 Intake Manifold Removal
Does anyone know if you can actually take the intake manifold off an H22 in an EG with the engine sitll in the car? I've never tried, I'm think of removing the manifold to clean the inside of it. Definetly is a limited about of space to work.
I thought of perhaps removing the manifold in 3 peices, maybe that would be easier? Anyone with experience feel free to share some knowledge. Thanks.
Old Jan 23, 2007 | 09:10 PM
Bakeoff's Avatar
Default Re: H22 Intake Manifold Removal (h22sedan)
trial and error, man. It might work if you remove the upper plenum. Without removing that, you're **** out of luck.
If you do it, definitely post back with the results so anyone searching for it has the answer in the future.
Old Feb 13, 2007 | 12:30 AM
strokedb16's Avatar
Default Re: H22 Intake Manifold Removal (Bakeoff)
well it is quite simple i had mine of already the complete manifold i just did it by sections i took the top plenum off then the butterflies anen unbolted it from block took 30 minutes at very most just be careful the bolts underneith are a lil tricky but u will get them u cant mess anything up good luck bro let us know how u did!!
JDMonster3790
Mar 4, 2009 07:40 PM
kikeh22
Oct 13, 2004 05:46 AM
MrMike
May 21, 2004 10:52 AM
MrMike
May 20, 2004 03:14 PM
