Solid Cel - Ecu is good, no fuel pump prime.
Old Jan 23, 2007 | 06:54 PM
floored4door's Avatar
Default Solid Cel - Ecu is good, no fuel pump prime.
B18c in a EG, finished my wire tuck but now this issue. SOLID CEL can't pull any codes, fuel pump doesn't prime. Main relay is good, ECU fuse is also good. I need help with any and all possibilities.
Old Jan 24, 2007 | 07:17 AM
Default Re: Solid Cel - Ecu is good, no fuel pump prime. (floored4door)
bump....
Old Jan 24, 2007 | 07:19 AM
Syndacate's Avatar
Usually it means the ECU is screwed.
Though as you so eloquently put it, the "ECU is good." Therefore I don't know.
Old Jan 24, 2007 | 10:01 AM
Default Re: Solid Cel - Ecu is good, no fuel pump prime. (Syndacate)
i tried the ECU in my friends car and it works, so I know it not the ECU.
Old Feb 19, 2007 | 12:28 PM
lCHaCHeel's Avatar
bump gopt a similar problem any answers??
Old Aug 2, 2007 | 12:57 PM
4potnick's Avatar
Default Re: Solid Cel - Ecu is good, no fuel pump prime. (lCHaCHeel)
same problem for me.,
Old Aug 6, 2007 | 09:31 PM
highrev1987's Avatar
Default Re: Solid Cel - Ecu is good, no fuel pump prime. (4potnick)
i was just searching around and found this cause i just fixed mine:
check the grounds all of them.
is it cranking??
if yes might be the thermostat ground
if no tranny ground
Old Aug 6, 2007 | 09:33 PM
xXSilentScreamXx's Avatar
Default Re: Solid Cel - Ecu is good, no fuel pump prime. (highrev1987)
i have the same problem weres the thermo ground?
Old Aug 6, 2007 | 09:44 PM
Default Re: Solid Cel - Ecu is good, no fuel pump prime. (xXSilentScreamXx)
its on the thermostat housing
Old Aug 6, 2007 | 09:57 PM
ok i checkd that its good ... see https://honda-tech.com/zeropost?cmd=fshow&id=1
Old Aug 7, 2007 | 06:23 AM
Mike
I had the same problem check ALL, and I mean every single fuse for a broken link.
One is broken I bet.
Old Aug 7, 2007 | 06:43 AM
Slammd Sol's Avatar
check ALL fuses, check/change your main relay, check ALL the engine grounds, perform the main relay test in the helms manual, check for continuity from the wires on the main relay to their destination (ecu, fuel pump, etc)
Old Aug 7, 2007 | 07:09 AM
f22beast's Avatar
Default Re: (Slammd Sol)
Check the ACG i made a thread about it recently try searching "ACG fuse WTF story"
The fuse is just under the air bag fuse inside the CAR not in the bay.
Ej8_KiD
Jul 15, 2013 11:02 AM
mouab18c1
13
Jul 23, 2011 05:23 PM
JT2
Honda Civic (2001 - 2005)
Jun 23, 2009 06:37 PM
forcefed22
Sep 18, 2008 08:18 PM
2 0 3
Jul 30, 2006 05:36 PM
