Solid Cel - Ecu is good, no fuel pump prime.
B18c in a EG, finished my wire tuck but now this issue. SOLID CEL can't pull any codes, fuel pump doesn't prime. Main relay is good, ECU fuse is also good. I need help with any and all possibilities.
Re: Solid Cel - Ecu is good, no fuel pump prime. (floored4door)
Usually it means the ECU is screwed.
Though as you so eloquently put it, the "ECU is good." Therefore I don't know.
Re: Solid Cel - Ecu is good, no fuel pump prime. (4potnick)
i was just searching around and found this cause i just fixed mine:
check the grounds all of them.
is it cranking??
if yes might be the thermostat ground
if no tranny ground
is it cranking??
if no tranny ground
Re: Solid Cel - Ecu is good, no fuel pump prime. (highrev1987)
ok i checkd that its good ... see https://honda-tech.com/zeropost?cmd=fshow&id=1
Re: Solid Cel - Ecu is good, no fuel pump prime. (xXSilentScreamXx)
I had the same problem check ALL, and I mean every single fuse for a broken link.
One is broken I bet.
check ALL fuses, check/change your main relay, check ALL the engine grounds, perform the main relay test in the helms manual, check for continuity from the wires on the main relay to their destination (ecu, fuel pump, etc)
mouab18c1
13
07-23-2011 05:23 PM
forcefed22
09-18-2008 08:18 PM
2 0 3
07-30-2006 05:36 PM
