Solid CEL (searched)
Old Jan 23, 2007 | 05:55 PM
H9Omega's Avatar
Default Solid CEL (searched)
OK, 96 integra LS/VTEC obd2 > obd1 conversion harness. Car ran fine, parked it at work, lunch time came around didn't crank. Changed distributor,ecu and main relay. Car doesn't crank, not getting any fuel nor spark. I have no idea what is wrong. Valve cover ground is there and so is transmission ground. Im stumped I had to tow the car home and now im stumped! Any help will be greatly appreciated, the ecu by the way is a stock p28, my other one is getting chipped as we speak.
Old Jan 23, 2007 | 06:33 PM
JasonST's Avatar
Default Re: Solid CEL (H9Omega)
So u saying that ur ecu is giving u a solid cel, as in the cel won't blink or turn off just always on? if that's the case, I member reading that's a problem with the ecu itself.
Old Jan 23, 2007 | 06:57 PM
H9Omega's Avatar
yeah, the fuel pump doesnt prime nor am i getting any spark. I replaced the three major components and checked all fuses and grounds
Old Jan 24, 2007 | 07:37 AM
H9Omega's Avatar
HELP!
Old Jan 24, 2007 | 12:29 PM
H9Omega's Avatar
where the gurus at?!?!
the.tetrix
Aug 15, 2017 03:58 PM
dragon909boi
Jul 9, 2015 08:42 PM
jtjtjt
22
Feb 17, 2012 02:46 PM
DA_9
Mar 11, 2008 03:17 PM
4potnick
12
Aug 21, 2005 01:59 PM
