Need Help Quick!! Axle Problem.
Old Jan 23, 2007 | 02:44 PM
5poonhatch's Avatar
Default Need Help Quick!! Axle Problem.
Ok heres the deal. My axle got messed up and i need a new one. The driver side one. I have a jdm b16 with a cable y1 trans. Ive heard that they axels are diff between cable and hydro trannys. Am i right or no? Ok. I need to know where i can find the axle i need with the plate that bolts onto the block. Any suggestions will help. Thanks.
Old Jan 23, 2007 | 03:02 PM
5poonhatch's Avatar
Bump.
Old Jan 23, 2007 | 03:25 PM
5poonhatch's Avatar
Default Re: (5poonhatch)
Ok heres a pic. I need the part on the bottom. Its called a half shaft right?
Old Jan 23, 2007 | 03:29 PM
sicones's Avatar
that part with the torn boot IS the axel, pry it out of the half shaft (it's 2 different pieces), there is nothing wrong with the half shaft
Old Jan 23, 2007 | 03:31 PM
5poonhatch's Avatar
Yea i know the half shaft is fine. BUT the part that goes into the hub is stripped. Meaning that theres no more teeth ob it. So where can i get that part?
Old Jan 23, 2007 | 03:32 PM
sicones's Avatar
are you talking about the splines inside the boot
Old Jan 23, 2007 | 03:39 PM
5poonhatch's Avatar
nvm i just found out what i need. Thanks anyways.
eric416
Sep 19, 2009 10:16 AM
kroze
Transmission & Drivetrain
10
Jul 7, 2009 02:09 PM
EGPrelude
Jun 17, 2008 07:46 AM
jacoop86
Aug 11, 2006 04:07 PM
