Interior lights malfunction
Old Jan 23, 2007 | 01:24 PM
Tc72's Avatar
Default Interior lights malfunction
When opening the drivers side door of my '03 Accord LX, the door and overhead
light's will not illuminate. The fuses and bulb's all check out. Opening the passenger
side door works as expected, both the overhead and door light will turn on.
The rest of the interior lights also work as expected. Any suggestions to a possible
cause/solution would be most welcome. Thanks.
Tim
Old Jan 23, 2007 | 02:07 PM
TheMuffinMan's Avatar
He knows where you live!
my guess is the sensor on your driver door is the one at fault (the one that senses if it's open/closed)
Old Jan 23, 2007 | 03:21 PM
hondadude's Avatar
Default Re: Interior lights malfunction (Tc72)
If your car has the 'slider' switch on the door post; you might remove it[phillips screw] and try cleaning up the contact point with your wifes fingernail emery board.
thisguyaves
Honda CR-V & Element
Nov 4, 2018 08:08 AM
HondaPilot777
Dec 3, 2013 05:07 PM
Joshua Hill
Feb 18, 2013 08:25 PM
taney
Honda Civic (2006 - 2015)
Jan 19, 2007 10:11 PM
