Wiseco Pistons 9:1?
Old Jan 23, 2007 | 12:06 PM
colinproctor's Avatar
Default Wiseco Pistons 9:1?
i need to know the Piston Dome Displacement for Wiseco 9:1 81.5 pistons.
i was about to order some from 1320online.com ( aka turboparts on HT ) and they have them listed as b18c1-5 8.6-8.9:1 compression or 9.7-10.2:1 compression. i dont know which ones i need in order to make 9:1 compression with my setup, b18c1 block with ITR head?
Old Jan 23, 2007 | 04:02 PM
boosted92's Avatar
Default Re: Wiseco Pistons 9:1? (FdOoUoRr)
I'm going to take a completely random, off the wall, never been thought of before, in the dark WILD suggestion here and say check out http://www.wiseco.com and then browse through there 2007 Sport Compact Catalogue. I don't know if it would work or not, but there's a slight chance that they just might have the dish/dome volumes listed on their website. If that doesn't work, god forbid you might just have to pick up a phone, call and ask!
Old Jan 23, 2007 | 04:41 PM
HiProfile's Avatar
Default Re: Wiseco Pistons 9:1? (boosted92)
Then once you get the cc of the piston, you can play with any of the hundred of online compresson calcs by plugging in all the pertinant info. Very infrequently will you find the exact comp # from a piston mfg, as they blanket the whole range and give only a rough estimate.
Old Jan 23, 2007 | 10:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to take a completely random, off the wall, never been thought of before, in the dark WILD suggestion here and say check out http://www.wiseco.com and then browse through there 2007 Sport Compact Catalogue. I don't know if it would work or not, but there's a slight chance that they just might have the dish/dome volumes listed on their website. If that doesn't work, god forbid you might just have to pick up a phone, call and ask!</TD></TR></TABLE>
i am not sure but i think Honda-Tech is a forum where you can ask technical questions if you need to? just a thought.
Old Jan 24, 2007 | 12:09 PM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FdOoUoRr &raquo;</TD></TR><TR><TD CLASS="quote">
i am not sure but i think Honda-Tech is a forum where you can ask technical questions if you need to? just a thought.</TD></TR></TABLE>
What's technical about being too lazy to go look on a product website to find out the info for yourself?
Old Jan 24, 2007 | 12:16 PM
What's technical about being too lazy to go look on a product website to find out the info for yourself?</TD></TR></TABLE>
actually their website even had the piston dome displacement listed wrong. i called and figured out the real cc's.
thanks for you help though! ( no sarcasm whatsoever )
kevinoneill
Jan 16, 2004 09:24 AM
JDM 007
Jan 24, 2003 01:08 PM
JDM 007
Jan 24, 2003 01:07 PM
turbo Si
Jun 26, 2002 04:28 AM
