brakes suk! cant stop
Old Jan 23, 2007 | 01:57 AM
AK_20_EM1's Avatar
Default brakes suk! cant stop
alright my rommate has a 03 accord coupe. she tells me she needs new brake pads so i buy them, go to put them on and wut do you know, they are perfectly fine. so i notice the rotors look warped so i buy new rotors. i replace them along with the new pads and the car acts the same way. umm when im coming to a complete stop the passenger front tire locks up as if it were on ice or wet surface. the abs in the rain is crazyyyy. i have to press really hard on the pedal to stop the car. it sucks she, or we have to drive slow *** ***. at every stop the abs kicks in like if i slammed on the brakes i blead the brake and it seems fine. any help before going back to honda???????? has this crap happened to n e 1 else???
Old Jan 23, 2007 | 03:20 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: brakes suk! cant stop (AK_20_EM1)
not that this has happened to me but... how do you tell a rotor looks warped? If it's so far out that you can see something is seriously wrong.
Old Jan 23, 2007 | 04:07 AM
TheMuffinMan's Avatar
He knows where you live!
ABS shouldn't be activating every time you stop should it? I wouldn't expect it to in the rain.
Did you get craptastic rotors? Sounds like either a ABS thingy (is the light on?) or isn't it possible for pads to get glazed?
Old Jan 23, 2007 | 03:23 PM
AK_20_EM1's Avatar
i replaced them with wearever gold. the best ones that discount offers. i use those on my itr brakes and they work like champs. i pulled the abs lever thingy and turned it off. the brakes worked good *** *** but the tcs doesnt work. im just gonna take the car to honda tomorrow to see if the warranty covers the booster and abs pump.
Old Jan 23, 2007 | 03:25 PM
AK_20_EM1's Avatar
all help is appreciated fellas. Thanx!
Old Jan 23, 2007 | 04:12 PM
JDM_DC4_Fanatic's Avatar
why are you guessing at parts? who says that just because the abs is coming on means its the pump? Have you ever stoped to check the calipers? maybe the problem is in the rear. we had an '01 civic come into the shop with an abs problem similiar to yours. The rear wheel cylender was leaking, it soaked the shoes and the one wheel wouldent stop, so the abs thought it was in a skid. Check the sliders on the caliper bolts as well as the piston itself. check the rear brakes as well. Its never a good idea to throw parts at something and hope that it will be fixed.
Old Jan 24, 2007 | 02:24 AM
YeuEmMaiMai's Avatar
car under warranty? if so don't mess with it and take it to the dealer. sounds like a ABS problem to me.....
Old Jan 25, 2007 | 11:01 AM
Betio1212's Avatar
tru wut fanatic says. none of the calipers leak. all pads are chunky, rotors are fine. im just dropping the car off on the weekend at honda. cars is very scary in the rain. i aint tryin to rear end someone. well thanx for replies.
Old Jan 30, 2007 | 06:38 PM
AK_20_EM1's Avatar
haha damn honda!!! recall on the abs pump haha.
Old Jan 30, 2007 | 09:16 PM
EvenStar's Avatar
bring it the mechanic man... this is yo life!
Old Jan 31, 2007 | 03:55 PM
FRISBEE's Avatar
make sure you didnt put the pads upside down they tend to walk out of their seat making it feel like they need bleeding. and also reinstall the little phillips screws that hold the rotors in place don't expect the wheel to hold it.
Old Jan 31, 2007 | 05:50 PM
Default Re: (FRISBEE)
haha, you think its those 2 dinky screws that hold the rotor to the car? I would put the studs over those stupid screws any day. Those screws are more of a convenience then for safty. Its the studs and wheel that really keep the rotor in place
Old Jan 31, 2007 | 06:02 PM
hondadude's Avatar
Default Re: (JDM_DC4_Fanatic)
think of those screws as keeping the rotor from hitting the studs
Old Feb 1, 2007 | 08:15 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FRISBEE &raquo;</TD></TR><TR><TD CLASS="quote">make sure you didnt put the pads upside down they tend to walk out of their seat making it feel like they need bleeding. and also reinstall the little phillips screws that hold the rotors in place don't expect the wheel to hold it.</TD></TR></TABLE>LOL
Which to you suppose has greater clamping force?
1) One little countersunk phillips screw
-or-
2) Four 12mm bolts tightened to 80 lbf*ft
Hint:
The little screw is for convenience on the assembly line; so the rotors don't keep falling off.
RACETEGGY
Jul 8, 2014 03:36 AM
Eric Buschman
Honda CR-V & Element
Jun 1, 2013 10:01 AM
BoltonGSR
Apr 8, 2009 05:31 PM
dLo GSR-stolen-now-WRX
Sep 30, 2004 06:53 AM
RiCE On IcE 2
May 10, 2004 02:26 PM
