B20 intake manifold question.......true or not??????
Old May 16, 2002 | 09:04 AM
Charlie Moua's Avatar
Default B20 intake manifold question.......true or not??????
OK I'M STILL UNSURE ABOUT THIS....................................
it's the manifold that won't clear the hood right? NOT the B20 head/valve cover right?
Old May 16, 2002 | 09:06 AM
EP3_05's Avatar
Default Re: B20 intake manifold question.......true or not?????? (Charlie)
One of the b20 models has an intake manifold similar to the LS manifold. The other model has the tunnel ram style intake manifold that will not clear the hood.
Old May 16, 2002 | 09:13 AM
Default Re: B20 intake manifold question.......true or not?????? (91civic)
THANKS MUCH
Old May 16, 2002 | 11:40 AM
Mazmay's Avatar
If i'm not mistaken:
b20b has the giraffe tall intake manifold that won't clear the hood.
b20z has the intake mani similar to the b18a/b
Old May 16, 2002 | 02:50 PM
Jared's Avatar
Default Re: B20 intake manifold question.......true or not?????? (beatdown88hf)
However, both the B20 manifolds make less power than an LS on the B20 does.
Old May 16, 2002 | 04:32 PM
Default Re: B20 intake manifold question.......true or not?????? (Jared)
so which one do i use(going to a 91 civic) 90 to 93 or 94+
Old May 16, 2002 | 05:26 PM
rioninja's Avatar
It doesnt make a difference, as long as you get all the sensors with it. Dont go too new or else it wont have an intake temp sensor on it though (white sensor on one of the runners). If you go with a newer one, all you gotta do is extend your map sensor wires so they reach your new throttlebody mounted map. b
Old May 16, 2002 | 08:54 PM
StorminMatt's Avatar
Although the B20Z intake manifold is similar to the LS manifold, it has a resonator box on top of it. It is very likely this will not fit under the hood, either.
irideslammed5021
Jun 9, 2007 07:46 AM
fatboy
Feb 13, 2003 01:25 AM
Arturbo
Jan 21, 2003 12:40 PM
Spade
May 20, 2002 06:55 AM
