k20 to k24
the k24 is not a 2.2L its a 2.4
its not just bored out, its got a completly differnt crank, different rods, pistons, etc etc, rod length is different, its a pretty different motor but still alot alike
So, it could be said that a K24 is a stroked K20... except that it's also taller, and not just gaining stroke via the crank.
One of the build options for a K24 block is to "de-stroke" it (using an F20C crank, I believe) to raise the safe rev limit in terms of piston speeds.
i had said the k24 was 2.2L ... i cant where i found that out but just cause it says its k24 doesnt mean that its 2.4L ... hmmm ... i may be wrong ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inkong »</TD></TR><TR><TD CLASS="quote">i had said the k24 was 2.2L ... i cant where i found that out but just cause it says its k24 doesnt mean that its 2.4L ... hmmm ... i may be wrong ...
It's 2.4L. Honda uses a certain naming convention for a reason - the H22 is 2.2L; the H23 is 2.3L; the B18 is 1.8L, and so on.
</TD></TR></TABLE>It's 2.4L. Honda uses a certain naming convention for a reason - the H22 is 2.2L; the H23 is 2.3L; the B18 is 1.8L, and so on.
Its actually ~ 2.35 but Honda likes to round things off more than I do.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BarracksSi »</TD></TR><TR><TD CLASS="quote">So, it could be said that a K24 is a stroked K20... except that it's also taller, and not just gaining stroke via the crank.
One of the build options for a K24 block is to "de-stroke" it (using an F20C crank, I believe) to raise the safe rev limit in terms of piston speeds.</TD></TR></TABLE>
You can actually use either the F20C at 84mm or the F22C at 90.7mm. The F20C in a K24 block would make for a really crazy short stroke/long rod combonation, and IIRC would net you about 1.8L where the F22C would net you about 2.15L on a stock bore.
I'll help you out on this. It's 2.4L.
http://en.wikipedia.org/wiki/Honda_K_engine
</TD></TR></TABLE>I'll help you out on this. It's 2.4L.
jdm_rb20
17
Mar 6, 2013 07:43 PM
