question about CTR cams
Old May 16, 2002 | 08:43 AM
VSMSiR_jon's Avatar
Default question about CTR cams
i might want to buy a set up of ctr cams off this guy but i want to know what kinda gains am i looking at here? i drive a 2000 civic SI(R) and those cams should drop right in with no problems right? they also come with a set of AEM cam gears. are there any people using this setup or have experience with them? i would like to know as much info as possible thanks! oh yea and how much do think they are worth (used for 20,000km)?
[Modified by VSMSiR_jon, 6:04 PM 5/16/2002]
Old May 16, 2002 | 08:44 AM
E. Honda's Avatar
Default Re: question about CTR cams (VSMSiR_jon)
I am also curios about this, would it be better to go with CTR or ITR cams for the SiR?
Old May 16, 2002 | 09:41 AM
Doctor CorteZ's Avatar
junk the AEM gears and upgrade to ITR drivetrain
Old May 16, 2002 | 09:42 AM
Default Re: question about CTR cams (CDM SiR)
exhaust cams are the same for 00-up ITR
ctr intake is 3 degrees higher lift , slight edge over the 2k ITR grinds
Old May 16, 2002 | 10:19 AM
neveronlines2k's Avatar
Get the CTR intake cam and the ITR exhaust cam . For tuning you'll need some type of V-Tech controller (to dial in the cams) your car is OBD-2 ,so you could just get a chipped p28 and a jumper harness.
Old May 16, 2002 | 10:49 AM
Oh ya, The gains from these cams probably about 7-10 horsepower with tuning its not a mod you'll really notice but the cams will help as you keep tuning you'r car. If you want some gains and a pretty much stock idle stay with the factory (ITR,CTR) cams
If you'r looking for larger gains go with stage 2 skunks or type three jun cams or stage three skunks. Hope that helps.
Old Jul 21, 2002 | 04:13 PM
vtec2nr's Avatar
Default Re: question about CTR cams (Doctor CorteZ)
FYI, the CTR intake cam has 3 degrees more duration NOT higher lift!
Old Jul 21, 2002 | 04:20 PM
vinceman's Avatar
Default Re: question about CTR cams (vtec2nr)
so would a ctr cam and 2000 GSR ecu work ok together?
Old Jul 21, 2002 | 04:22 PM
rodrez.'s Avatar
When I upgraded to CTR cams I definately noticed a difference. Get the CTR intake cam at least. As far as the AEM's, I had a set on my old car, and they slipped once, which I was not happy with. My friend H-T user "Opi" just put a set on, and one of the bolts was stripped, after just 2 dyno sessions on the previous owners car, w/an experienced tuner. If you can afford it, upgrade the valvetrain, TypeR would work very well.
Old Jul 21, 2002 | 06:10 PM
blackANESE's Avatar
FYI 2000-2001 ITR cams are exactly the same as CTR cams.
The 95+ ITR cams have 3 deg. less duration, with lift and everything else
being equal.
Old Jul 21, 2002 | 06:30 PM
allmtr's Avatar
Default Re: question about CTR cams (blackANESE)
blackANESE is sooooo correct
Old Jul 22, 2002 | 07:47 AM
oops , I always type the opposite of what I'm thinking on dur/lift
thanks
Old Jul 22, 2002 | 09:41 AM
714eg's Avatar
Who the **** really gives a rats *** buy either one!
Old Jul 22, 2002 | 09:48 AM
Default Re: question about CTR cams (714si)
About the AEM cam gears I have had mine for 2 1/2 years and have never had them slip after adjustments make sure there tourqued to spec and you shouldn't have any problems with those gears
Old Jul 22, 2002 | 10:47 AM
Apex i ITR's Avatar
From: Toronto, Canada currently residing in ATL, GA, USA
Default Re: question about CTR cams (stuckatworksi)
There has been talk about the exhaust cam on the 2000 up ITR being identical to the CTR that's why a lot of them dyno higher the 97-99 ITR's. There was a big debate because the cams were being made i na diff facility in Japan and blah blah blah.
I have see nwith my own eyes how the PY and FB ITR's do seem to be faster stock for stock for some weird reason.
Old Jul 23, 2002 | 09:09 PM
vtec2nr's Avatar
Default Re: question about CTR cams (Apex i ITR)
The exhaust cams of all the ITRs and the CTR are exactly the same.
Vinceman: Yes, a CTR intake and/or both CTR cams will do just fine with a 2000 GSR ECU. You will want to adjust the vtec x-over a little higher and then adjust the fuel map between the stock vtec engagement point and the new point, with a VAFC. You will see decent gains over stock cams.
BlackANESE: Can you verify that the 00-01 ITRs have the same intake cam as the CTRs? Some H-T members claim to have measured the cams and found differences and my friend who works for Honda Verno in Japan verified that they have different part numbers in Japan.
[Modified by vtec2nr, 1:19 AM 7/24/2002]
rico suave
May 27, 2012 09:32 PM
thrty8street
Oct 27, 2003 07:44 AM
AllMoToRB18c
Oct 26, 2003 02:33 PM
R-Adrenaline
Sep 18, 2001 12:06 PM
1GreyTeg
Aug 26, 2001 10:20 AM
