vtec pressure valve
Old Jan 22, 2007 | 04:47 PM
shaggy420's Avatar
Default vtec pressure valve
cel code 22, do i need to replace the whole vtec solenoid or is there another way to fix it?
Old Jan 22, 2007 | 04:52 PM
Luserkid's Avatar
Default Re: vtec pressure valve (shaggy420)
Do you have oil?
Old Jan 22, 2007 | 04:56 PM
hondachris1994's Avatar
Default Re: vtec pressure valve (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Do you have oil? </TD></TR></TABLE>+1 definatelly check oil, or check the wires goin to the vtec solinoid
Old Jan 22, 2007 | 05:00 PM
shaggy420's Avatar
oil pressure is reading normal but ill check the oil just in case. been a couple weeks since i changed it
Old Jan 22, 2007 | 05:09 PM
Default Re: (shaggy420)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaggy420 &raquo;</TD></TR><TR><TD CLASS="quote">oil pressure is reading normal but ill check the oil just in case. been a couple weeks since i changed it </TD></TR></TABLE>u only have to change your oli every 3,000 miles, not every cpl weeks, and the reason we say check your oil is cause when that code gets thrown it uasually means your about 2 quarts of oil low
PH3593A
11
Jul 19, 2023 02:36 AM
egmatt93
Dec 5, 2006 08:29 PM
vi3t00si
12
May 31, 2006 11:49 AM
untitled
Aug 13, 2003 10:37 AM
BeeResp0nsible
Nov 29, 2002 05:43 AM
