What is the difference between Main And Head Studs?
Old Jan 22, 2007 | 04:40 PM
JBsRomeoAlon's Avatar
Default What is the difference between Main And Head Studs?
What is the difference between Main And Head Studs? I need studs for my valve cover because one snapped and two others won't completely tighten, just keep on turning. What studs do I exactly need?
Old Jan 22, 2007 | 05:10 PM
doood's Avatar
been there done that
Default Re: What is the difference between Main And Head Studs? (JBsRomeoAlon)
headstuds go into the deck of the block and hold the head down. main studs go in the bottom of the block and hold the main caps down.
Old Jan 22, 2007 | 05:13 PM
Default Re: What is the difference between Main And Head Studs? (doood)
So what do I need to bolt down my valve cover? If I was to go onto a website and they have different stud options what exactly is the part called for my valve cover stud? Or is it just called Valve Cover Stud? -From the completely confused human
Old Jan 22, 2007 | 07:32 PM
WanaBeFaster's Avatar
Do you need the bolt itself or just the nut?
Old Jan 22, 2007 | 07:48 PM
95 integra's Avatar
Default Re: (WanaBeFaster)
Look under cylinder head and cylinder head cover for the studs. The part will vary if you have a LS or GSR, but you should be able to get it from here since they have pretty little diagrams. If you dont....take it to a shop.
http://www.acuraparts247.com/catdisplay.jsp
http://www.acuraparts247.com/p...ch=no
VietSpeed
Dec 31, 2008 06:07 PM
mtny
May 24, 2006 04:04 PM
turboJDMeg6
Mar 28, 2005 08:21 PM
Phoenix_ITR
Dec 25, 2002 09:46 PM
quickLSt
Sep 9, 2001 10:56 PM
