Chrome and VAFC
Old Jan 22, 2007 | 03:59 PM
1GPlusSH's Avatar
Default Chrome and VAFC
I am finally going to tune with chrome on my 97 Prelude(ODB1). I want to keep my VAFC just so that I can check my driving characteristics. Are the fuel settings going to override my tune or work with my tune? I know wherever I set the vtec engagement with the VAFC will override my tune, but I'm not sure about the fuel.
Old Jan 22, 2007 | 04:07 PM
TDCTyler's Avatar
Default Re: Chrome and VAFC (1GPlusSH)
after using CROME there is no reason to use your fmu. CROME does everything and more than your fmu, just sell it or something. they are not comtable with one another.
btw: which ecu and version of crome are you using?
Old Jan 22, 2007 | 04:11 PM
1GPlusSH's Avatar
Default Re: Chrome and VAFC (spOolin97)
I know they're compatible, and I realize I don't need the VAFC. I'm just wondering about the fuel settings. Does the VAFC override or work with the settings on my chip?
I'm going to keep the VAFC on there for now, if it doesn't override.
Old Jan 22, 2007 | 04:25 PM
TDCTyler's Avatar
i would assume that it would override........cause thats what its made to do.
i could see that turning into a mess, just get rid of the vafc
Modified by spOolin97 at 10:53 PM 1/22/2007
Old Jan 22, 2007 | 05:29 PM
v4lu3s's Avatar
RTFM
even "zeroed" i have seen vafc's expletive up fueling pretty badly.
i put my car on the dyno with "zeroed" vafc and with a near stock setup i somehow ended up at 16:1 afr under full throttle....
Old Jan 22, 2007 | 05:34 PM
PrecisionH23a's Avatar
You can change your fueling with crome. Adding the v-afc is just a waste of time and money.
Old Jan 22, 2007 | 06:13 PM
98vtec's Avatar
moderator emeritus
Default Re: Chrome and VAFC (PrecisionH23a)
two engine management systems are not needed. More wires = more problems to diagnose in the event of electrical shortage.
Old Jan 23, 2007 | 02:52 PM
1GPlusSH's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">even "zeroed" i have seen vafc's expletive up fueling pretty badly.
i put my car on the dyno with "zeroed" vafc and with a near stock setup i somehow ended up at 16:1 afr under full throttle....</TD></TR></TABLE>
thanks, man. this is what i was needing to know.
Old Jan 23, 2007 | 03:41 PM
ricedadee's Avatar
Default Re: (1GPlusSH)
Somebody needs to read a manual
Old Jan 27, 2007 | 11:49 AM
ricedadee's Avatar
Default Re: (ricedadee)
there is a way to keep Vafc this diagram is from Vafc 1 it only requires little work
typesguy
Sep 30, 2005 12:27 PM
B18CRacer
Apr 29, 2004 11:40 AM
spooned out
Aug 25, 2003 06:31 PM
sharkey65a
Jan 20, 2003 08:20 PM
K20A
Jul 28, 2002 09:44 PM
