How are these valves looking??? 56k Warning
looks fine to me.
I never liked the divider on Intake to be ported so sharp.
http://theoldone.com/articles/....html
The valves dont look that bad. Id be more worried about the gouges in the cc as they could cause hot spots. Id personally use a stock head. That port job doesnt look like itd perform too well. Whoever did that was very inconsistant on the short turn.
take the valves out clean them with a wire wheel. Inspect them for damage.
check if there is alot of play in the valve guides. Lap the valves check if they are seated at the right angle. Put new valve seals in it if you are going to use it.
It's a cheap rebuild. I will run you around $40-50 in parts but you will know that everything is right.
BTW those valve guides look chopped way down so there is a good chance there is alot of play in them. You might need to replace them.
Looks like time to replace the valves.The edges look like they are starting to erode from the pictures."Chipping" on the edges is an indication that they have gotten to hot.
DJYoshaBYD
Dec 9, 2009 10:59 AM
importfan0103
Oct 5, 2005 04:02 PM
