primer removal help
Old Jan 22, 2007 | 12:26 PM
exotik4doorcivic's Avatar
Default primer removal help
i have a car that someone stole and primered, but whoever stole it didnt scuff the clear,
wondering if anyone knows any thing that will remove the primer but not the clear
because the paint was in good condition
Old Jan 22, 2007 | 01:49 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: primer removal help (exotik4doorcivic)
I doubt you can remove the primer and not damage the clear. If you had Ins. just tell em what the deal is and re-paint it whatever color you want.
Old Jan 22, 2007 | 03:20 PM
Default Re: primer removal help (ek forever guy)
there is nothing that is clear coat safe??
i just bought the car this way, but i knew the person who owned it,
if you you use your fingernail you can scracth of the primer and see the paint undernieth which is shiny/glossy
it will just takes days to scratch all of it off
Old Jan 22, 2007 | 03:22 PM
e jay one's Avatar
well if it comes off that easy hit it whith a high power pressure washer.
Old Jan 22, 2007 | 03:34 PM
Archidictus's Avatar
Unceasing Measure
Default Re: primer removal help (e jay one)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one &raquo;</TD></TR><TR><TD CLASS="quote">well if it comes off that easy hit it whith a high power pressure washer.</TD></TR></TABLE>
Agreed. You can also try a product by Sparkle Auto that's made for removing graffiti. I used it to get white road marker paint off a black Chevy Blazer and it worked like a charm. Don't use it on plastic parts
The pressure washer might work, though
Old Jan 22, 2007 | 04:11 PM
Default Re: primer removal help (Archidictus)
ok i tried pressure washing, and i tried wd40 because i heard that can be used to break apart the solvents, but it almost seams as if its a flat black paint??
Old Jan 22, 2007 | 04:17 PM
JSPECSIR's Avatar
cheap primer is laquer based, it will wipe off with laquer thinner. i would however ask a body shop the effects of the laquer thinner on you clearcoat.
Old Jan 22, 2007 | 04:52 PM
Default Re: primer removal help (JSPECSIR)
is flat back the same as primer??
Old Jan 22, 2007 | 05:34 PM
JSPECSIR's Avatar
it comes in diff. colors
Old Jan 22, 2007 | 05:50 PM
MonkeyBoy668's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exotik4doorcivic &raquo;</TD></TR><TR><TD CLASS="quote">is flat back the same as primer??</TD></TR></TABLE>
Primer can be flat black, but primer is available in a lot of different colors (light grey, orange/red, etc).
Flat black primer tends to come out on the grey side of black in my experience, while flat black paint tends to be darker.
I'd try getting a small amount of the stuff Archidictus mentioned and spot-testing it on an inconspicuous part of the car (lower quarter panels, etc).
Basically you want something tough enough to remove the paint but not enough to damage the clearcoat. My gut says taking thinner to it would end badly, but my gut was created before clearcoat finishes.
Old Jan 29, 2007 | 02:39 PM
ekhatch7's Avatar
there is nothing you can do but repaint expecially if you care what your car looks like
Old Jan 29, 2007 | 02:54 PM
medside's Avatar
Default Re: primer removal help (ekhatch7)
what you want to do is wet sand it off, I would suggest starting out with a coarser sandpaper, then when you get most of the primer off you want to go to a really fine sandpaper. you will sand into the first layer of clear coat, but then you polish it out and wax it. I'm pretty sure that is how its done.
I would search for painting hot rods.
I know for the Hot Rod guys they always end up sanding out the last layer of clear. they actually do it throughout the painting process to get rid of imperfections and the orange peel look.
Good Luck
xd69
Detailing
Apr 7, 2010 10:15 PM
dcfreak
Paint and Body
May 22, 2008 09:51 PM
[Eg.6]LiLbOy916
Oct 28, 2006 09:23 AM
HatchBox
Feb 7, 2005 06:16 PM
PolyPill
Feb 4, 2005 06:54 AM
