Clutch Masters Flywheel Inserts?
Old Jan 22, 2007 | 08:06 AM
HTLuver's Avatar
Default Clutch Masters Flywheel Inserts?
I need to get a new flywheel insert for my CM flywheel. CM gave me a quot of $104. Does any one know where I can get one cheeper?
Also, I found some inserts for a Fidanza flywheel for around $50. Will Fidanza flywheel insert fit on the CM flywheel?
Old Jan 22, 2007 | 08:15 AM
Padawan's Avatar
Darth ModerVader
Default Re: Clutch Masters Flywheel Inserts? (HTLuver)
The Fidanza and Clutch Masters flywheels are the same. Any CM or Fidanza dealer should be able to get the friction surface for you.
Old Jan 22, 2007 | 08:30 AM
HTLuver's Avatar
Default Re: Clutch Masters Flywheel Inserts? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">The Fidanza and Clutch Masters flywheels are the same.</TD></TR></TABLE>
That's cool. I'm gonna get the Fidanza flywheel insert then, but if anyone has tried it and it doesn't fit, please let me know other wise, I am going to pick one up.
Old Jan 22, 2007 | 08:34 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HTLuver &raquo;</TD></TR><TR><TD CLASS="quote">but if anyone has tried it and it doesn't fit, please let me know other wise, I am going to pick one up.</TD></TR></TABLE>
Yes, you should definitely double-check (perhaps give Fidanza a call). All of the information I've seen states that the two are identical except for the colour, but there may be subtle differences that could affect the fitment of the friction surface.
Old Jan 22, 2007 | 08:43 AM
HTLuver's Avatar
Alright, anyone else. . .
I know there has to be somebody out there that has a CM flywheel that's ran into this question. I did a search but didn't find a definite yes or no, or a good price.
Old Jan 24, 2007 | 03:41 AM
HTLuver's Avatar
Anyone???
Old Jan 24, 2007 | 08:58 AM
mikeycivic's Avatar
Default Re: (HTLuver)
what exactly are flywheel inserts?
Old Jan 24, 2007 | 09:06 AM
seabass10369's Avatar
Default Re: (mikeycivic)
I am understanding this as when the flywheel surface and starter ring gear are made of different material and the gear is pressed onto the outer surface of the friction surface. I think the friction surface in this case is aluminum with a steel gear.
But then again maybe this is sumthing else
Old Jan 24, 2007 | 09:13 AM
HTLuver's Avatar
Default Re: (seabass10369)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by seabass10369 &raquo;</TD></TR><TR><TD CLASS="quote">I am understanding this as when the flywheel surface and starter ring gear are made of different material and the gear is pressed onto the outer surface of the friction surface. I think the friction surface in this case is aluminum with a steel gear.
But then again maybe this is sumthing else</TD></TR></TABLE>
Right
http://www.clutchmasters.com/s...=6265
Old Jan 25, 2007 | 09:16 AM
mikeycivic's Avatar
gotcha
Old Jan 25, 2007 | 09:43 AM
Padawan's Avatar
Darth ModerVader
Not exactly, but you have the right idea.
The flywheel is machined from aluminium, and the starter ring is indeed steel. However, the "friction surface" is the replaceable section on the aluminium that contacts the clutch, and is constructed from steel.
Old Jan 25, 2007 | 12:08 PM
HTLuver's Avatar
Anyone else with cm flywheel?
Old Feb 26, 2007 | 01:20 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
TTT
im looking right now for that very same info..
i have heard in the past that they were the same hoevery when i had both flywheels i never verified that and now i need inserts for the CM fly. i might just order the fidenza and take the risk and see
msbhvn_DC2
May 18, 2006 05:01 PM
.one lane
Dec 12, 2005 09:22 AM
mattdenali
Sep 13, 2005 04:19 PM
Dc_John
Apr 2, 2004 07:57 PM
Nextelbuddy
Feb 8, 2004 07:56 PM
