stock 13's and disc conversion
Old Jan 22, 2007 | 05:51 AM
HondaHeddie's Avatar
Default stock 13's and disc conversion
will any of the disc conversions fit inside the stock 13 steelies?
if so, is it a disc conv worth doing ?
Old Jan 22, 2007 | 06:14 AM
steronz's Avatar
If we're talking about rear disks, then 13s should fit over them no problem. Is it worth it? For stopping power, the general concensus is no. For bling and/or ease of changing pads, then it's a personal decision.
Old Jan 22, 2007 | 02:05 PM
mahatma's Avatar
Default Re: stock 13's and disc conversion (HondaHeddie)
i'd rather do 5 entire rear disc conversions than change rear drums ONCE.....
so for me, yes it's worth it
Old Jan 22, 2007 | 04:14 PM
Crx Jimmy's Avatar
yes if your keep your stock front brakes and just swap rears the 13's will work
Old Jan 22, 2007 | 04:24 PM
91ed9's Avatar
Default Re: stock 13's and disc conversion (Crx Jimmy)
stock 13's willl work, and personal preferance wheather its worth it to do it, i like 4 wheel disc better, easier to change andi thinkthey stop better you dont have to adjust them all the time like drum brakes
Old Jan 22, 2007 | 05:36 PM
gsxr1k05's Avatar
i did this swap and they do fit. it is well worth it. i did the 1 inch master cylinder and teg booster swap as well. just have to change the line fitting for one brake line to the 4040 valve with the 1 inch mc.. but well worth it. and easy as hell.. use si ebrake cables.. the teg ones work (its what i got) but are a little long and you have to crank the ebrake adjuster as much as possible...
Old Jan 22, 2007 | 06:07 PM
ef-hatchcrap's Avatar
Default Re: (gsxr1k05)
I just did the rear disc swap today on my car. I found very little diffrence in breaking power.
My buddy stupidslowrsx said I have to get the 4040 prop valve to feel the diffrence.
only1odz
Honda Fit
Jun 18, 2017 08:16 PM
89 civic si
Oct 26, 2006 06:42 PM
eghatchomar
22
Jan 9, 2005 08:20 PM
advanracing62
Jul 7, 2002 06:22 PM
djay86
Apr 10, 2002 01:46 PM
