vibration problem help!
Old Jan 21, 2007 | 05:39 PM
2wheelhunter's Avatar
Default do you need the rubber ring around the axle?
My cv joint clicking so i replaced both axles with brand new ones, they did not have the rubber rings around the axles. on the test drive there was no clicking at all but now it vibrates pretty bad under acceleration. could i have gotten bad axles?is it because there is not the rubber peice that goes around the middle of it?
Modified by 2wheelhunter at 7:10 PM 1/21/2007
Modified by 2wheelhunter at 8:05 PM 1/21/2007
Old Jan 21, 2007 | 07:06 PM
Default Re: do you need the rubber ring around the axle? (2wheelhunter)
ttt for help
Old Jan 21, 2007 | 07:21 PM
hondamark35's Avatar
no. i install rebuilt axles without those rubber deals all the time and never have problems. double check all of your work, make sure bolts are all tight, make sure the shafts are all the way in the trans. where did you get the axles?
Old Jan 21, 2007 | 07:27 PM
Default Re: do you need the rubber ring around the axle? (hondamark35)
they were from advance auto parts
Old Jan 21, 2007 | 07:42 PM
any one else with this problem?
Old Jan 21, 2007 | 08:01 PM
smileycvc's Avatar
axles could be bent. I got a bent refubished axle from NAPA once. Check to make sure the axle is installed properly if not try swaping it out with a new one.
Old Jan 21, 2007 | 08:23 PM
KimChiKid's Avatar
Make sure everything is bolted up and that the axles are all the way in.
raidacaipo
60
Sep 4, 2010 09:04 PM
Oreo-TeCk
Jul 1, 2007 10:33 PM
Teglessb18
Suspension & Brakes
Apr 4, 2006 12:58 PM
jdmskin
Oct 15, 2003 09:16 AM
hioctane3
Apr 25, 2003 10:21 AM
