Which cams for daily drive
Old Jan 21, 2007 | 03:32 PM
kuki's Avatar
Default Which cams for daily drive
Hello. I'm bilding my new engine B18C 2.1 L block CR around 12.5 with ITR head. What you think which cams will be the best for my engine for daily drive and give me much power
1. Skunk2 S2
2. Jun type 3
3. Toda C2
4. Skunk2 S2Pro
5. your opinion
Old Jan 21, 2007 | 03:42 PM
tecnic1's Avatar
Default Re: Which cams for daily drive (kuki)
s2s2 here...
stock primary == stock idle. Drives like a stock car off the cam.
Old Jan 21, 2007 | 04:29 PM
UncleD's Avatar
Default Re: Which cams for daily drive (tecnic1)
M22x or Pro1.
Old Jan 21, 2007 | 05:21 PM
1 2 NV's Avatar
skunk2 stg 2 = JUN 3s. any of those 3 would be my choice. i think the pro 2s are the way to go. newer cam profile than the JUN 3s.n Pro 2 because your running a 2L. although i think any of the above cams you mentioned will work.
i keep seeing this **** though. is your motor truly a 12.5:1 motor or are you just going off the pistons specs? a long time ago i had some supposed 12.5:1 pistons in my motor. by the time you figure PTDH, gasket etc etc they were actually only 11.3:1.
Old Jan 21, 2007 | 05:30 PM
JDM DERF's Avatar
Default Re: Which cams for daily drive (1 2 NV)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 2 NV &raquo;</TD></TR><TR><TD CLASS="quote">skunk2 stg 2 = JUN 3s. any of those 3 would be my choice. i think the pro 2s are the way to go. newer cam profile than the JUN 3s.n Pro 2 because your running a 2L. although i think any of the above cams you mentioned will work.
i keep seeing this **** though. is your motor truly a 12.5:1 motor or are you just going off the pistons specs? a long time ago i had some supposed 12.5:1 pistons in my motor. by the time you figure PTDH, gasket etc etc they were actually only 11.3:1.</TD></TR></TABLE>
i agree
Old Jan 21, 2007 | 09:35 PM
LABjunkies's Avatar
either skunks and the todas will do well with some bit of a mild tune
Old Jan 21, 2007 | 10:01 PM
sdr KEL's Avatar
Default Re: Which cams for daily drive (LABjunkies)
blox type b
Old Jan 22, 2007 | 12:20 AM
kuki's Avatar
But you thnik is possible to use skunk2 s2pro in daily driven ? .
Information about 12.5 I have from seller of my shortblock
Old Jan 22, 2007 | 05:23 AM
1 2 NV's Avatar
people daily drive on pro 2s all day long already. why would it be any different for your car?
Old Jan 23, 2007 | 04:48 AM
krystianitr's Avatar
Toda c2 Made is Japan
I had skunk2 stage 2 with my b18 and cam brake
Look https://honda-tech.com/zerothread?id=1548817
Old Jan 23, 2007 | 05:03 AM
IntegraType-R's Avatar
Default Re: Which cams for daily drive (krystianitr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krystianitr &raquo;</TD></TR><TR><TD CLASS="quote">Toda c2 Made is Japan
Look https://honda-tech.com/zerothread?id=1548817 </TD></TR></TABLE>
Just because you have bad luck doesn't mean everyone else does...
i've been running the s2s2's for just about a year now..no problems..
I did break some crane stage 2's i bought from a guy on honda-tech about a year ago but they were already precracked..and neither him nor i knew..just took a good rev to 9300rpms to find out..lucky even after that rev..it didn't actually break until i just was pulling away from a stop light at like 1k rpms..nothing broken, or bent..
I currently run these cams.. my motor is a 99 usdm type-r, with a 3layer oem HG, ferrea HC SS valves, and a jdm b18c head milled 0.020 of an inch, cr is 11.8~12.0. These cams are great.
Old Jan 23, 2007 | 05:05 AM
1 2 NV's Avatar
JUN 3s made in japan. exhaust cam broke in 5 pieces.
Old Jan 23, 2007 | 08:43 AM
my9thtry's Avatar
Default Re: Which cams for daily drive (JDM_G2)
no he is saying sometimes, **** breaks!
Old Jan 23, 2007 | 09:49 AM
1 2 NV's Avatar
what im saying is that blanket statement the moron said 2 posts above my last was pretty ignorant.
spelling isnt that important but its BREAK
Old Jan 23, 2007 | 10:19 AM
Blueprint's Avatar
skunk2
Old Jan 23, 2007 | 11:37 AM
doood's Avatar
been there done that
Default Re: Which cams for daily drive (Blueprint)
cams break more often than not due to installer error. you can break any cam if installed incorrectly.
pimpinblackcivic
26
May 20, 2007 01:35 PM
neophyte210
38
Oct 3, 2005 10:04 AM
Cashflo
Mar 5, 2003 03:09 PM
slooowDX
Oct 8, 2002 11:56 AM
JDMvtecDRAGSTA
Jul 22, 2002 01:21 AM
