Cold start hesitation and low RPM's.
Since it's been colder outside my car has been having some difficulties starting up. When it does fire up though, the rpm's stay very low (around 1000) and only go up to normal, around 1500 rpm, after about 30-45 secs. Is this normal or can something be done.
The motor is a 99 gsr with a obd-1 p72 ecu.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by platinumx6 »</TD></TR><TR><TD CLASS="quote">i thought the FITV causes it to idle high?? </TD></TR></TABLE>
It raises the engine speed (RPM) when it's cold so it can warm up faster (as running cold is bad for the engine). If it's jammed up and not working properly it could be hesitating to speed the RPM up. Hense the slow idle at first, then speeding up and working like it's supposed to when it unjams.
I guess i had the inner working of it confused...If the valve inside isnt screwed tight it idles high but when its snug it idles normal, and this is on a spring right? how would it jam?
On the sticky on this site you clean the IACV not the FITV, you just tighten the valve? i dont really care mine fixed when i tightened it i was just wandering
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate »</TD></TR><TR><TD CLASS="quote">Crap gets in there, clogs it up, hence the process of "cleaning it."</TD></TR></TABLE>
Still doing it...a little more about my motor. 1999 GSR, edelbrock throttle body, skunk2 intake manifold, stock cams, low comp pistons, n/a for the winter, forged internals...
From what I hear, forged internals hate the cold. The metal takes longer to expand and can create a little piston slap at cold startup. Could the pistons and rings just not be sealing against the cylinder walls for those first few seconds? I noticed that if I tap the gas right at startup the engine seems to hickup a little. Trying to move the car with the stage 2 clutch is very tricky unless the engine is warmed up.
did you get it working right? im having the exact same problem. im thinking it has something to do with crome and some of the settings. i have tried different things but as soon as it starts its around 9afr.
Shauntron
Apr 25, 2007 12:06 AM
