Gear Oil in 90' 5 Speed
Old Jan 21, 2007 | 09:58 AM
Gsir8's Avatar
Default Gear Oil in 90' 5 Speed
I just changed the clutch about 1000 miles ago, and replaced the oil in the transmission with 10w 40 motor oil like it recommended in the book. But now when sometimes when I shift into 3rd gear it grinds a little, and doesnt engage smoothly. I was wondering if I put regular gear oil in the transmission would it be bad for it? And will this problem with 3rd gear possibly go away?
Old Jan 21, 2007 | 10:38 AM
TheMuffinMan's Avatar
He knows where you live!
GM Synchromesh my friend, it'll save you alot of trouble helps with grinds like no other, the other alternative is Honda MTF rather than the motor oil. You can buy that at a Honda Dealership and get the Synchromesh from a GM dealer
Old Jan 21, 2007 | 11:11 AM
hondadude's Avatar
Default Re: (TheMuffinMan)
you can also get the little bottles of GM LSD additive from the Honda dealer; they stock them for use in the passports rear diff. add one little bottle for each fluid change.
I'd vote for a lighter weight oil as well. 10w30 maybe
Old Jan 21, 2007 | 01:26 PM
Chiovnidca's Avatar
Try some honda mtf. Do not use gear oil!!!
Old Jan 21, 2007 | 01:57 PM
::MYCORD::'s Avatar
Default Re: (Chiovnidca)
yeah, honda mtf is sooo much better than motor oil
Old Jan 21, 2007 | 02:49 PM
standbackimapro's Avatar
Try BG Synchroshift II,
OR
75w90 Gear oil with 2 bottles of lucas transmisson fix
Old Jan 21, 2007 | 06:50 PM
Gsir8's Avatar
It takes like 2 quarts right? How much would that cost of Honda MTF or Syncromesh? And if I don't stop the grinding will it eventually get worse?
Old Jan 21, 2007 | 08:25 PM
fleetw00d's Avatar
Default Re: (Gsir8)
I made the mistake of using 10W30 in my 90 Accord; long story short, I had to replace the transmission (shop wanted $1100 to rebuild the original one). Use the Honda MTF. 2 quarts will be less than $10 (I think).
Old Jan 22, 2007 | 12:16 AM
HDR's Avatar
HDR
yea, i have this same problem, right now im using mobil1 HP 10w 30. none of the dealerships here sell honda MTF or GM sychromesh! what's the best motor oil to use? royal purple?
Old Jan 22, 2007 | 08:49 AM
iam7head's Avatar
Default Re: (standbackimapro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by standbackimapro &raquo;</TD></TR><TR><TD CLASS="quote">Try BG Synchroshift II,
OR
75w90 Gear oil with 2 bottles of lucas transmisson fix</TD></TR></TABLE>
stupid idea
using 75w90 for gear box design for 10w30 is just stupid, wanna try peanut oil?
Old Jan 22, 2007 | 02:46 PM
Blamm!!'s Avatar
Default Re: (iam7head)
yeah- do NOT use gear oil and or lucas additive under any circumstance for daily driving!!
Old Jan 22, 2007 | 04:17 PM
hondadude's Avatar
Default Re: (fleetw00d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fleetw00d &raquo;</TD></TR><TR><TD CLASS="quote">I made the mistake of using 10W30 in my 90 Accord</TD></TR></TABLE>
Odd to see that; 10w30 or 10w40 was the designated fluid for that year because Honda didn't have their own MTF fluid at that time.
Old Jan 22, 2007 | 07:13 PM
alterdcreations's Avatar
Default Re: (hondadude)
0w20 moble one syntec also in the tranny
jdm702
Apr 15, 2010 04:50 AM
MtnCRX
Apr 24, 2005 06:36 PM
wizzards581
Mar 4, 2003 09:41 PM
Type R 01
Feb 12, 2003 04:35 AM
