running issues
Old Jan 21, 2007 | 08:44 AM
sohctodohc's Avatar
Default running issues
ok so i drive an ej1 and i threw cel 9 a month ago so i replaced the distributor. which fixed the issue with the cel. but now when i start the car and either hit the gas a lil bit or reverse it a lil bit it wants to die it drops to like a couple hundred rpms and everything dims down like its gonna die then catches itself and hops back up in the rpms.
and sometimes when it does this it will actually die and when i go to start it back up it takes awhile for it to actually start up and sounds like it is running on 2 or 3 cylinders and it will finally work itself out of this.
is it the distributor or what????
Old Jan 21, 2007 | 08:49 AM
INCNTRL4's Avatar
Default Re: running issues (sohctodohc)
check all ur plugs/wires would be your cheapest bet
Old Jan 21, 2007 | 09:56 AM
sohctodohc's Avatar
Default Re: running issues (INCNTRL4)
done changed plugs wires are fine they are ngk blues that arent even a year old. the weird thing is it only does this when it is cold...
Old Jan 21, 2007 | 10:01 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohctodohc &raquo;</TD></TR><TR><TD CLASS="quote">done changed plugs wires are fine they are ngk blues that arent even a year old. the weird thing is it only does this when it is cold...</TD></TR></TABLE>
Yes, they're not even a year old, therefore they MUST NOT have ANY part of the problem, right?
Old Jan 21, 2007 | 10:48 AM
sohctodohc's Avatar
Default Re: running issues (Syndacate)
ummm i have done inspected them if i had any problems with them then i would of said hey guys i thinks my wires are bad
and if there was a problem with them the problem would be consistent and not just when the engine is cold
Old Jan 29, 2007 | 04:18 PM
sohctodohc's Avatar
ttt for any other suggestions
teamTakeo
Aug 20, 2023 07:58 PM
micah13x
11
Apr 14, 2011 03:09 PM
EJ8_Enthusiast
Jun 15, 2009 06:02 PM
D.Dappa
Jan 31, 2007 08:36 PM
itrdriver1071
May 14, 2005 08:18 AM
