CODE 19 Automatic transmission lockup control valve
Old Jan 21, 2007 | 08:14 AM
Soichiro-son's Avatar
Default CODE 19 Automatic transmission lockup control valve
I have a check engine light and it is throwing code 19 (Automatic transmission lockup control valve). I have a manual transmission. Any idea if what could be the problem? Maybe another noob question.
Thanks
Old Jan 21, 2007 | 08:23 AM
Default Re: CODE 19 Automatic transmission lockup control valve (Soichiro-son)
I found the problem.
Come to find out I have an Auto ECU.
nsxmatt's Avatar
Did you do a auto to manual swap or are running a auto ECU? If neither, reset the ECU and see if it comes back.
Old Mar 19, 2007 | 04:39 PM
donvillarin's Avatar
Default Re: CODE 19 Automatic transmission lockup control valve (nsxmatt)
hi i have a auto to manual conversion the problem is code 19 which is the automatic transmission control valve . i already change my ecu to manual ecu. then reset. it still appears in my cel. what are others possible links couses that problem? is there some one could help me? i have a d16a engine only.... and i dont know what is the problem with auto matic trany lockup control valve...
Old Mar 19, 2007 | 05:43 PM
hi shoichiro my name is don i have same problem with your b4... but still my cel is on light. what else couses those check engine lights?
Old Mar 19, 2007 | 05:46 PM
hi matt do you have any idea of automatic transmission lockup conrtol valve is? coz i do the swap yo auto to manual....
jserman
Feb 20, 2007 11:54 PM
gsxr1k05
Oct 25, 2006 08:21 AM
crnimacak
Dec 31, 2005 04:30 PM
your username here
Nov 29, 2003 04:58 PM
virginia_dude
Nov 14, 2003 06:44 PM
