d 15 b ignition advance.
Old Jan 21, 2007 | 05:05 AM
bluebeast's Avatar
Default d 15 b ignition advance.
Greetings.Maybe someone here can help.I have a d15b with a few simple bolt ons,4-2-1 header ,de cat pipe,long induction kit.I run the car on 95 octane fuel,would it benefit from advancing/ retarding the ignition timing.Appreciate any sensible suggestions.
Old Jan 21, 2007 | 07:59 AM
suspendedHatch's Avatar
Default Re: d 15 b ignition advance. (bluebeast)
You can benefit by setting it to the high side of spec. For example, if the spec for your car is 16+/- 2 (and I'm not saying that it is), then 18 degrees advanced is most likely going to give you the most power without risking detonation, poor fuel economy and emissions.
The only real way to know is to tune it on a dyno. But it generally isn't cost effective unless you're also tuning at least a cam gear and a fpr.
Old Jan 22, 2007 | 10:23 AM
bluebeast's Avatar
Default Re: d 15 b ignition advance. (suspendedHatch)
it is 16 btdc,so u reckon 2deg advance woudlnt hurt?whats fpr?
Old Jan 22, 2007 | 10:25 AM
bluebeast's Avatar
oh i get it fuel pressure regulator,are they any use?
Old Jan 22, 2007 | 10:38 AM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by suspendedHatch &raquo;</TD></TR><TR><TD CLASS="quote">You can benefit by setting it to the high side of spec. For example, if the spec for your car is 16+/- 2 (and I'm not saying that it is), then 18 degrees advanced is most likely going to give you the most power without risking detonation, poor fuel economy and emissions.
The only real way to know is to tune it on a dyno. But it generally isn't cost effective unless you're also tuning at least a cam gear and a fpr.</TD></TR></TABLE>
Old Jan 23, 2007 | 12:07 AM
dubzxallxstar's Avatar
ur gonna put a hole in ur piston...good luck...
garyc17
Jul 5, 2006 04:54 AM
jeremy.
Oct 2, 2003 06:27 PM
sohcvtec1995
Aug 29, 2003 09:50 AM
Eric R
Jun 12, 2003 05:11 AM
7rrivera7
May 14, 2003 08:28 AM
