b-series swap question. axles???
Old Jan 20, 2007 | 11:34 PM
dem0nk1d's Avatar
Default b-series swap question. axles???
once i've dropped my first b-series motor into my eg. Will the stock ls/gsr integra axles bolt into the hub/spindles. Or do i have to swap the end "splines of axles to civic"?
Old Jan 20, 2007 | 11:38 PM
fmrprojects's Avatar
Default Re: b-series swap question. axles??? (dem0nk1d)
they are a direct fit
Old Jan 21, 2007 | 12:17 AM
VRD^don's Avatar
Default Re: b-series swap question. axles??? (fmrprojects)
should be direct fit as said above...dont pull on the axles alot..or else you'll have to take them apart!!
Old Jan 21, 2007 | 01:50 AM
:Andrew's Avatar
Default Re: b-series swap question. axles??? (k_motor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k_motor &raquo;</TD></TR><TR><TD CLASS="quote">should be direct fit as said above...dont pull on the axles alot..or else you'll have to take them apart!!</TD></TR></TABLE>
and that's not cool
TotalBalance
Suspension & Brakes
Sep 13, 2007 11:45 AM
MEBHB91
Aug 17, 2006 12:09 PM
415Hatch
May 30, 2005 12:38 PM
turkdog
Nov 27, 2003 04:05 PM
youngwon22
Oct 14, 2003 07:47 PM
