F22A6 help
my engine started runin rough a couple of days ago so replace da spark plugs and wires and it still is runin rough den did da disturbor and still missing fire on da second cylinder so i think i bent a vaule or slip timing cause it shoudlt still be missin firing. so im going to pull da head off and see if i have any bent vaules so on that note anyone have a head for sale.
Got da F22A6 think i bent a couple vaules so instead of puttin new vaules in and **** im plan on just swaping da whole head and **** but want to do another swap on da head but was wonderin wat other heads fit i heard about da F20 or da F22B1 or B2 head swap anybody know of anything else there is to do or got a A6 head for sale/
do a compression test on cylinder 2, if you have a bent valve there will be no compression. Theres no need to guess at whats wrong with the car. Dont just throw parts at it and hope it goes away. First off, make sure you have the correct firing order, then check timing, then check the compression. find the answers to those questions and come back with more info.
hotintegranights
Jan 4, 2003 11:40 AM
