question about my clutch...
Old Jan 20, 2007 | 07:45 PM
lamboextreme's Avatar
Default question about my clutch...
well when i bought my car 00 SI, the guy said it had a performance clutch, well sometimes the clutch seems to have two engaging point on first gear. when I'm releasing the clutch it catches really quick and the it looses the engagement and as i keep releasing the clutch it engages again. is the clutch going bad?
Old Jan 20, 2007 | 08:00 PM
ifIexplode's Avatar
2nd stage?
Old Jan 20, 2007 | 08:27 PM
Default Re: (ifIexplode)
i think he said the brand was performance racing clutch or something close to it.
Old Jan 29, 2007 | 03:31 PM
Default Re: (lamboextreme)
anyone?
Old Jan 29, 2007 | 03:43 PM
Libertariat's Avatar
Ek Forever y0!
Sounds like it was an F1 racing clutch.
Just a guess though, they're okay. I've only heard one or two bad reviews, of 12-20 reviews I've heard, all others were great.
Old Jan 29, 2007 | 06:39 PM
Default Re: (ek forever guy)
so it's o.k. if only sometimes it enganges in like two different RPMS in first gear?
Old Jan 29, 2007 | 07:19 PM
MonkeyBoy668's Avatar
Have you double-checked that your clutch fluid reservoir is filled up?
My clutch does strange things when the fluid gets low. Check the level, pump the clutch pedal a half dozen or more times, then check the reservoir again to see if the level changed at all. If it's still at the line then at least it isn't your fluid.
Old Jan 29, 2007 | 08:03 PM
Default Re: (MonkeyBoy668)
i'll try that and see if it works.
Old Jan 29, 2007 | 08:22 PM
RedEj8's Avatar
Ive had one of those f1 racing clutches for 15k miles and i have no problems..Maybe its that new 2-stage clutch.
You might need to bleed your clutch system.
andlude
Apr 5, 2012 07:45 PM
-Championship-
Sep 12, 2006 01:01 PM
range
Dec 1, 2003 02:01 AM
SuperRice
Jun 6, 2003 11:24 AM
SuperRice
Jun 6, 2003 07:53 AM
