rpm tach
Old Jan 20, 2007 | 05:02 PM
pdx_503's Avatar
Default rpm tach
For quite some time now, when excellerating up to a high rpm the tach on my gauge jumps up and down. It doesn't stay at a constant rpm. Whats weird about it though is that it doesn't happen all the time. Only every once and a while. Feedback please.
Old Jan 20, 2007 | 05:14 PM
b16er's Avatar
Default Re: rpm tach (pdx_503)
It means your car is in self-destruct mode.
Old Jan 20, 2007 | 05:17 PM
dr_latino999's Avatar
Default Re: rpm tach (b16er)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16er &raquo;</TD></TR><TR><TD CLASS="quote">It means your car is in self-destruct mode. </TD></TR></TABLE> True story, saw a ricer take out three city blocks that way.
In all reality it means your tachometer signal is breaking up due to some odd electrical interference. Make sure your all your connections between the distributor and the cluster are nice and tight.
Old Jan 20, 2007 | 05:19 PM
betsy84's Avatar
My guess is that's your dist. wire, or your ground is way off. But I'd double check your green wire (if its aftermarket) aka your distributor wire it may be not right.
and its ACCELERATING
Old Jan 20, 2007 | 05:23 PM
mar778c's Avatar
Community Builder
Community Influencer
Your dizzy is about to give you a hissy.
In all seriousiness, your distirbutor is going bad.
Old Jan 20, 2007 | 05:35 PM
Targa250R's Avatar
be professional
The stock tach needle is jumping but everything else seems fine?
This problem is typically caused by a failing distributor igniter. Replace the igniter. OEM is about $105; a good aftermarket one is betwteen $40-50.
Old Jan 20, 2007 | 06:27 PM
pdx_503's Avatar
Default Re: rpm tach (Targa250R)
Thanks guys. I will check it and see if thats the problem. Reply to my other topics as well.
wood 1
Oct 23, 2006 10:07 PM
b_serious
12
May 11, 2006 04:26 PM
99sibluehatchwitb16
Jan 26, 2006 09:45 PM
its WANG yoO
Dec 9, 2003 09:19 AM
Nerv2g
Oct 19, 2003 06:56 AM
