**EDIT** Will a 99-00 si exhaust fit on a 95 ex ??
Old Jan 20, 2007 | 04:06 PM
d!ckface's Avatar
Default **EDIT** Will a 99-00 si exhaust fit on a 95 ex ??
Old Jan 20, 2007 | 05:47 PM
MasterKwan's Avatar
Default Re: **EDIT** Will a 99-00 si exhaust fit on a 95 ex ?? (GSRh@tch)
I doubt it. Wheelbase is longer in the SI and all EK/EJ's. You could probably get someone to make it fit though.
Old Jan 20, 2007 | 05:58 PM
Eran's Avatar
HT White Ops
Default Re: **EDIT** Will a 99-00 si exhaust fit on a 95 ex ?? (MasterKwan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan &raquo;</TD></TR><TR><TD CLASS="quote">I doubt it. Wheelbase is longer in the SI and all EK/EJ's. You could probably get someone to make it fit though. </TD></TR></TABLE>
92-00 coupe/sedan exhaust is the same for SOHC/DOHC VTEC motors.
Old Jan 20, 2007 | 05:59 PM
fmrprojects's Avatar
it should fit. i gave an exhaust that was on my 95 coupe to my friend with a 2000 si and it fit
Old Jan 20, 2007 | 06:01 PM
kiddcarbuff's Avatar
Default Re: **EDIT** Will a 99-00 si exhaust fit on a 95 ex ?? (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">
92-00 coupe/sedan exhaust is the same for SOHC/DOHC VTEC motors.</TD></TR></TABLE>
yup. i have an evo 2 from an si on my 94 sedan. fits lke a glove
Old Jan 20, 2007 | 07:17 PM
blueb16-em1's Avatar
what everyone els said, it will fit
Old Jan 20, 2007 | 08:15 PM
99TurboBlue's Avatar
I'm a Jackass cause i dont like to follow the rules.
it should, bought cat-back exhaust on ebay for my first 99 civic si and even the box said will fit 99-00 dohc and 92-95 sohc
Old Jan 20, 2007 | 08:20 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan &raquo;</TD></TR><TR><TD CLASS="quote">I doubt it. Wheelbase is longer in the SI and all EK/EJ's.</TD></TR></TABLE>
Wheelbase is identical for all '92-00 coupes and sedans. Cat-back exhaust portion is also the same for those models except for D16Y5 and D16Y7 engines.
Old Jan 21, 2007 | 07:40 AM
d!ckface's Avatar
Default Re: **EDIT** Will a 99-00 si exhaust fit on a 95 ex ?? (Targa250R)
im running a gsr..
Old Jan 21, 2007 | 09:22 AM
MasterKwan's Avatar
Targa, he's asking about a 95 EG EX and an EK/EJ/EM. The wheel base changed from 95-96 with the change in models. I was trying to say, all 96-00 Civic's have the same wheel base. Maybe it didn't come out right.
I had to have a Buddy Club exhaust shortened to fit my EK/EJ with B18C5 swap.
Old Jan 21, 2007 | 09:34 AM
d!ckface's Avatar
so i have to get it shortend? how much shorter
Old Jan 21, 2007 | 09:49 AM
Eran's Avatar
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRh@tch &raquo;</TD></TR><TR><TD CLASS="quote">so i have to get it shortend? how much shorter</TD></TR></TABLE>
With my hatch, I had to cut off about 3-4" of my exhaust when I dropped in my B18B1.
Old Jan 21, 2007 | 09:53 AM
MasterKwan's Avatar
I had to take about 2" off mine. Cut it behind the cat to catpack flange then had the two pieces welded back together.
Old Jan 21, 2007 | 11:39 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan &raquo;</TD></TR><TR><TD CLASS="quote">Targa, he's asking about a 95 EG EX and an EK/EJ/EM. The wheel base changed from 95-96 with the change in models.</TD></TR></TABLE>
Only for hatchbacks. Coupe and sedan wheelbase remained the same from '92-00 at 103.2".
Old Jan 21, 2007 | 03:49 PM
MasterKwan's Avatar
So it did, I stand corrected.
I must have been thinking Integras. 2 Dr is 101.2 and 4 dr is 103.1.
Old Jan 22, 2007 | 08:29 AM
d!ckface's Avatar
im confused as ****. can i get a solid answer?
Old Jan 22, 2007 | 08:54 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRh@tch &raquo;</TD></TR><TR><TD CLASS="quote">im confused as ****. can i get a solid answer?</TD></TR></TABLE>
The exhaust from a '99-00 Civic Si 2dr will work on a '95 Civic EX (both 2dr and 4dr).
You would only run into problems if either of the cars was a 3dr.
Old Jan 22, 2007 | 02:27 PM
d!ckface's Avatar
ic ic. thanks bro
Old Jan 23, 2007 | 03:36 PM
d!ckface's Avatar
now will my stock exhaust fit on a eg hatch?
808k20a2
12
Aug 8, 2007 12:48 AM
hkboy87
Sep 25, 2006 11:19 AM
Flava
15
Jun 5, 2006 11:48 PM
SixguN
Nov 5, 2004 10:00 AM
PoWeRBaN_PaNdA
Jan 15, 2003 06:43 AM
