**EDIT** Will a 99-00 si exhaust fit on a 95 ex ??
Re: **EDIT** Will a 99-00 si exhaust fit on a 95 ex ?? (GSRh@tch)
I doubt it. Wheelbase is longer in the SI and all EK/EJ's. You could probably get someone to make it fit though.
HT White Ops
Re: **EDIT** Will a 99-00 si exhaust fit on a 95 ex ?? (MasterKwan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan »</TD></TR><TR><TD CLASS="quote">I doubt it. Wheelbase is longer in the SI and all EK/EJ's. You could probably get someone to make it fit though. </TD></TR></TABLE>
92-00 coupe/sedan exhaust is the same for SOHC/DOHC VTEC motors.
it should fit. i gave an exhaust that was on my 95 coupe to my friend with a 2000 si and it fit
Re: **EDIT** Will a 99-00 si exhaust fit on a 95 ex ?? (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran »</TD></TR><TR><TD CLASS="quote">
92-00 coupe/sedan exhaust is the same for SOHC/DOHC VTEC motors.</TD></TR></TABLE>
yup. i have an evo 2 from an si on my 94 sedan. fits lke a glove
I'm a Jackass cause i dont like to follow the rules.
it should, bought cat-back exhaust on ebay for my first 99 civic si and even the box said will fit 99-00 dohc and 92-95 sohc
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan »</TD></TR><TR><TD CLASS="quote">I doubt it. Wheelbase is longer in the SI and all EK/EJ's.</TD></TR></TABLE>
Wheelbase is identical for all '92-00 coupes and sedans. Cat-back exhaust portion is also the same for those models except for D16Y5 and D16Y7 engines.
Targa, he's asking about a 95 EG EX and an EK/EJ/EM. The wheel base changed from 95-96 with the change in models. I was trying to say, all 96-00 Civic's have the same wheel base. Maybe it didn't come out right.
I had to have a Buddy Club exhaust shortened to fit my EK/EJ with B18C5 swap.
HT White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRh@tch »</TD></TR><TR><TD CLASS="quote">so i have to get it shortend? how much shorter</TD></TR></TABLE>
With my hatch, I had to cut off about 3-4" of my exhaust when I dropped in my B18B1.
I had to take about 2" off mine. Cut it behind the cat to catpack flange then had the two pieces welded back together.
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MasterKwan »</TD></TR><TR><TD CLASS="quote">Targa, he's asking about a 95 EG EX and an EK/EJ/EM. The wheel base changed from 95-96 with the change in models.</TD></TR></TABLE>
Only for hatchbacks. Coupe and sedan wheelbase remained the same from '92-00 at 103.2".
Re: **EDIT** Will a 99-00 si exhaust fit on a 95 ex ?? (Targa250R)
So it did, I stand corrected.
I must have been thinking Integras. 2 Dr is 101.2 and 4 dr is 103.1.
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRh@tch »</TD></TR><TR><TD CLASS="quote">im confused as ****. can i get a solid answer?</TD></TR></TABLE>
The exhaust from a '99-00 Civic Si 2dr will work on a '95 Civic EX (both 2dr and 4dr).
You would only run into problems if either of the cars was a 3dr.
808k20a2
12
08-08-2007 12:48 AM
hkboy87
09-25-2006 11:19 AM
