Car not starting after swap.
Old Jan 20, 2007 | 02:55 PM
CiViC_SOHC's Avatar
Default Car not starting after swap.
Ok, so I am in desperate need of some help. I have a 1992 Honda civic LX, I took my old motor out in place of a built D16Z6. I ran into some problems with not having spark, I finally fixed that and then my fuel pump went out. Put a new one in today. Tried to start it and it is hesitant to start...It will make it want to turn over then just stop, and try again. The positive ground wire on the starter gets red hot and starts to smoke after awhile. I am getting fuel and spark but its just not firing. I believe I have the spark plugs right. The 1st one goes on the "C" terminal right? and the cylinder order is 4-3-2-1 correct? So my question is why do you think its no starting? Thanks for the help guys!
Old Jan 21, 2007 | 09:27 AM
CiViC_SOHC's Avatar
Default Re: Car not starting after swap. (CiViC_SOHC)
no one had any help?
Old Jan 21, 2007 | 12:55 PM
CiViC_SOHC's Avatar
ok, so I have I searched the forums and I still can't find out why it would not start. I have fuel and I have spark...It seems almost like the starter might be shorting out...how would I check? I don't have an extra starter to throw on there and try.
Old Jan 21, 2007 | 02:55 PM
walsh22's Avatar
Default Re: (CiViC_SOHC)
make sure ur dizzy is not upside down and the spark plugs are in the right holes
Old Jan 21, 2007 | 06:50 PM
CiViC_SOHC's Avatar
Default Re: (walsh22)
Upside down? How in the hell would that even make sense? It only bolts on one way man..and the spark plugs are in the correct holes, thx for the help though.
Old Jan 21, 2007 | 07:32 PM
hondamark35's Avatar
"C" terminal? also i hope your "ground wire" isn't positive. i understand typos, just want to make sure this is one before i suggest anything for you to try. also who built the motor?
Old Jan 21, 2007 | 07:48 PM
bigislandc2's Avatar
well if you have fuel and spark the car should start, you say that the car is haveing a hard time to turn over right? check how many amps the starter is pulling. and check thee valve timming
Old Jan 22, 2007 | 03:12 AM
CiViC_SOHC's Avatar
Default Re: Car not starting after swap. (hondamark35)
the ground is not positive, sorry, its the positive terminal from the battery to the starter that is getting hot. A reputable guy around my town built my motor, he has built tons of honda motors, valve timing is correct, he set it before he gave me the motor, the cam gear marks were even with the block when we lined up the timing belt.
reomi
Jul 18, 2008 04:43 AM
The Stance
May 17, 2007 02:53 PM
NoMiS
Jan 17, 2005 08:21 AM
neilff
21
Jul 31, 2003 12:17 PM
[626]95-GSR
30
Feb 16, 2002 12:06 PM
