tranny drainplug?! first one to get it right wins!
Old Jan 20, 2007 | 02:49 PM
vtec4lyfe's Avatar
Default tranny drainplug?! first one to get it right wins!
stupid no brainer question by me but for some reason i cannon remember which one is the tranny fill plug? i know the drain plug but is the fill hole 1, 2 or 3? i used to work at an oil change for a year and cant even remeber! i know the tranny takes 1.6 or 1.7 L but cant even remeber the fill plug!
btw its a b16b!
Old Jan 20, 2007 | 02:51 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: tranny drainplug?! first one to get it right wins! (vtec4lyfe)
I'll take answer #3 for $1000 Bob.
hondachris1994's Avatar
I fill mine through the VSS, but I have a B-series tranny
Old Jan 20, 2007 | 02:52 PM
Ek Forever y0!
Default Re: tranny drainplug?! first one to get it right wins! (ek forever guy)
DOh, fill plug is #2, i use number 3 to fill with.
EGwhat!!!'s Avatar
Old Jan 20, 2007 | 02:53 PM
vtec4lyfe's Avatar
you guys are confusing me!
EGwhat!!!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy &raquo;</TD></TR><TR><TD CLASS="quote">DOh, fill plug is #2, i use number 3 to fill with.</TD></TR></TABLE>
wrong again
Old Jan 20, 2007 | 02:54 PM
EGwhat!!!'s Avatar
Default Re: (vtec4lyfe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec4lyfe &raquo;</TD></TR><TR><TD CLASS="quote">you guys are confusing me!</TD></TR></TABLE>
its 1... 17mm. i think
Old Jan 20, 2007 | 02:55 PM
vtec4lyfe's Avatar
any forsures?
thanks to all btw
Old Jan 20, 2007 | 02:56 PM
EGwhat!!!'s Avatar
forsure its number 1
Old Jan 20, 2007 | 02:58 PM
AdamB18C1EK's Avatar
Default Re: (hondachris1994)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondachris1994 &raquo;</TD></TR><TR><TD CLASS="quote">I fill mine through the VSS, but I have a B-series tranny</TD></TR></TABLE>
lol so does he
Old Jan 20, 2007 | 03:05 PM
my_slow_civic's Avatar
Default Re: (EGwhat!!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGwhat!!! &raquo;</TD></TR><TR><TD CLASS="quote">forsure its number 1</TD></TR></TABLE>
Old Jan 20, 2007 | 03:09 PM
Default Re: (AdamB18C1EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AdamB18C1EK &raquo;</TD></TR><TR><TD CLASS="quote">
lol so does he </TD></TR></TABLE>Well then just fill it through the VSS and b done and its alot easyer to get to
Old Jan 20, 2007 | 03:17 PM
NJcoupe's Avatar
wow; are you guys serious?
#1 is the fill plug.
Old Jan 20, 2007 | 03:38 PM
Hondacivic90ed's Avatar
hmm which ones have crush washers on them.... that would be telltale sign they are meant to be removed/serviced. #2 is a plug removed to access the upper case snap ring, and #3 I believe allows you to gain access to another snap ring or detent ball, I can't remember, but for sure #1 is the fill plug its always behind the axle. It appears you have a bad axle seal as well, unless you already repaired that.
Old Jan 20, 2007 | 03:43 PM
djsire's Avatar
Default Re: (Hondacivic90ed)
wtf is wrong with you people.
lol
the fill plug is number 1,
your suppose to fill it until fluid pours back out.
then that means its full.
I however use the vss because im lazy. i think its 2.8 quarts.
Old Jan 20, 2007 | 04:31 PM
futurefastguy's Avatar
Default Re: (djsire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djsire &raquo;</TD></TR><TR><TD CLASS="quote">wtf is wrong with you people.
lol
I however use the vss because im lazy. i think its 2.8 quarts.</TD></TR></TABLE>
im pretty sure its 1.8-1.9 quarts.
Old Jan 20, 2007 | 04:38 PM
THE GUY's Avatar
Not to be confused with "THE MAN"
#1 is the fill. And you had the drain labeled correctly. I think it is 1.9 qts of fluid. The other 2 plugs you had labeled are bolts that cover snap rings that hold the gear shafts I believe.
Old Jan 20, 2007 | 04:45 PM
Eran's Avatar
HT White Ops
I use the breather nipple on top of the tranny, some silicone hose, and my hella-jdm tranny fluid pump:
Old Jan 20, 2007 | 05:20 PM
Z3120's Avatar
lol</TD></TR></TABLE>
That's HT members working hard for you. You're better of referring to a $14 manual from autozone or pepboy. djsire is correct, bolt #1 is the filler bolt.
Old Jan 20, 2007 | 05:31 PM
Erik95LS's Avatar
Default Re: tranny drainplug?! first one to get it right wins! (EGwhat!!!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGwhat!!! &raquo;</TD></TR><TR><TD CLASS="quote">1</TD></TR></TABLE>
its 1
Old Jan 20, 2007 | 05:34 PM
strictly.business's Avatar
Banned
ive used number 2 before. never had any problems.
Old Jan 20, 2007 | 06:09 PM
kaoss_11's Avatar
B A N N E D
Take out ur variable speed sensor and fill from the top of tranny much easier
Old Jan 20, 2007 | 06:10 PM
Jim Truett's Avatar
Default Re: (strictly.business)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strictly.business &raquo;</TD></TR><TR><TD CLASS="quote">ive used number 2 before. never had any problems. </TD></TR></TABLE>
Yeah, but your tranny was half full.
Old Jan 20, 2007 | 06:13 PM
shyboi4u's Avatar
looks like you need a new axle seal.....
