fan blower problems
Old Jan 20, 2007 | 02:47 PM
rojapar's Avatar
Default fan blower problems
I tried to do a search, but haven't really been bale to find the info i need. When i turn my fan on to blow air out the vents, it will work right about 90% of the time. Then sometimes, it will make a weird noise like a fan belt squeeling when it is on. It is not the air conditioner pump though, it is happening without the air being turned on.
Now, this noise can come and go just like that...but i have found if i change the fan speed, it will usually quit making the noise. The noise can happen at any fan speed...low or high, or somewhere in between.
From what i have found, i could have leaves in the fan or else the bearing is going out. I wouldn't think the bearing is going out because i would guess it would make a noise all the time if that were true. The leaves in there, maybe?
I took the glove box door off tonight to see the unit, but am not sure what to take apart next to see if there is leaves inside.
Anyone know if i am on the right track, and what i should take off next to fix the problem.
Thanks,
Rob
Old Jan 20, 2007 | 03:16 PM
ifIexplode's Avatar
Idk where to access the vents but when i got my 98ek peices of leaves blew out of my vents for like 2 months
Old Jan 20, 2007 | 03:25 PM
ekb16's Avatar
take out ur blower motor and clean it...stuff might of fell in there and that makes noise when u turn on the fan...it should be 3 screws under the glove box
fiebru1119
Mar 14, 2010 08:01 PM
honda2002
May 20, 2007 01:58 PM
ek4 coupe
Feb 15, 2007 03:28 PM
xkrntamax
Apr 17, 2006 06:38 AM
Mike1486
Dec 15, 2004 05:49 PM
