No Power
No Power
Hi I have a problem with my 95 sol vtec. Today I tried to start my car and i got no power whatsoever ! So I jump started it and it works fine now but my alarm does not work anymore... anyone know whats wrong ?
I never drove the car for 1 week and its snowing/freezing outside.. Also the power cable on the battery was loose.
Re: No Power (jit01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jit01 »</TD></TR><TR><TD CLASS="quote">Hi I have a problem with my 95 sol vtec. Today I tried to start my car and i got no power whatsoever ! So I jump started it and it works fine now but my alarm does not work anymore... anyone know whats wrong ?
I never drove the car for 1 week and its snowing/freezing outside.. Also the power cable on the battery was loose. </TD></TR></TABLE>
not to familiar with cold weather since it's not cold where i live, but first have the battery checked. if your battery is pretty old, not driving it for a week might have killed it.
also, tighten your battery cables, and double check ground wires. some might have gotten loose, or just need to be replaced.
The battery died because I never drove it for awhile and the wire was loose (barely on) it works fine now tho. But my alarm is still not working do you think maybe need to let the battery charge itself more ?
Re: (jit01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jit01 »</TD></TR><TR><TD CLASS="quote">The battery died because I never drove it for awhile and the wire was loose (barely on) it works fine now tho. But my alarm is still not working do you think maybe need to let the battery charge itself more ? </TD></TR></TABLE>
look for the fuses to the alarm. they might have blown.
Re: (jit01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jit01 »</TD></TR><TR><TD CLASS="quote">could it be that my batterly still does not have enough power to turn it on ? My alarm also locks my doors if that matters.. </TD></TR></TABLE>
not familiar with alarms, especially the one you have, but i would go have the battery checked, recharged or replaced and have the alternator checked or replaced as well.
then give it a try. also, how does your ground wires look. might want to consider on replacing them as well. process of elimination!
Re: (jit01)
Well if your car is running..then theres deffinately enough power to the alarm..I thought to reset them you uhh unhook it from the power and reconnect?
homegr0wn
05-15-2012 05:47 AM
rodimus
Audio / Security / Video
14
11-10-2005 09:53 PM
CRXracer88
02-03-2004 12:25 PM
