Apexi N1
i bet if you went to the big red search button it would give you the answer or if you werent so lazy you could go to the apexi website and they would tell you
have a good day
have a good day
Mine didn't, but mine was specifically for a civic...
Though that's the type of answer you get for asking a question like this.
EDIT:
It probably has a 2.5" or so and you'll just need to weld on a reducer pipe.
EDIT:
Dumbass did you run a search like i did? Well if you did then before you put ur fat fingers to the keyboard you would have know that there is no answer. As for going to the Apexi website I didnt think of it. You should have gone and got the answer and looked like hero instead of an *******. Because were here to help each other... Have a nice day!
Apexi offers a universal muffler with 2 inlet options:
Similar to the cat back system, the N1 universal uses premium polished SUS 304 stainless steel constructed using both robotic and hand crafted welding. Straight through design ensures maximum power on properly tuned exhaust systems. The N1 Universal incorporates a 60mm (2.36 in.) inlet and 90mm (3.54 in.) tip for naturally aspirated applications and an 75mm (3 in.) inlet with 115mm (4.53 in.) tip for turbocharged vehicles. Since this muffler is universal, the output angle of the exhaust can also be determined by the customer during installation.
slikz714
Jan 11, 2006 12:39 AM
