help car still wont start
Old Jan 20, 2007 | 07:56 AM
antiricer's Avatar
Default help car still wont start
i replaced the battery, and the main relay car still wont start, can anyone please help me out thanks
Old Jan 20, 2007 | 08:27 AM
EKris's Avatar
Default Re: help car still wont start (matixskater)
Alternator may be bad, and check fuses.
Old Jan 20, 2007 | 08:37 AM
antiricer's Avatar
Default Re: help car still wont start (EKris)
which fuses do i check, i checked the ecu fuse and its good what other fuses do i need to check
Old Jan 20, 2007 | 08:40 AM
EKris's Avatar
check the fuses under ur hood near the firewall and/or check the fuses under ur dassh. this was a problem with my buddys Prelude, and we thought he blew his alternator, but it was just the battery fuse. haha
Old Jan 20, 2007 | 08:44 AM
antiricer's Avatar
i went to start my car up just to se if it would and it did, it ran for about 10 seconds then it turned off, what could that mean
Old Jan 20, 2007 | 08:46 AM
MikeD718's Avatar
is it running rough? check to see if your dizzy is 180 out.
Old Jan 20, 2007 | 08:48 AM
EKris's Avatar
Default Re: (MikeD718)
yeah if thie dizzy isnt placed right, that mite b it..but u said u changed the battery? how long ago?
antiricer's Avatar
no it runs perfect for about 10 seconds then it shuts itself off
Old Jan 20, 2007 | 08:49 AM
antiricer's Avatar
Default Re: (EKris)
i replaced the battery about 4 days ago
Old Jan 20, 2007 | 08:51 AM
EKris's Avatar
Default Re: (matixskater)
o, it shuts off by itself.....hrmmms... well, im really thinkn its ur battery, but u said u changed it, but if u changed it, not to long ago and ran on that, it would drain ur battery out and because if ur alternator is bad, then the car would b running on the battery. but thats prolly not it...so u can start ur car anytime? but shuts off every 10sec.?
Old Jan 20, 2007 | 08:55 AM
antiricer's Avatar
Default Re: (EKris)
no i can start it up itll run for the 10 sec, then itll turn off ill try to turn back on and it wont
Old Jan 20, 2007 | 09:10 AM
EKris's Avatar
yeah man im havin the same problem, and kame to find out its my alternator. kuhz when i got my new battery it ran perfect but then the nex day it began to die out on me, and when i tried turnin it on it wouldnt start, so i had to jump it. and i took it for a test, my alternator was bad. so thats probably whats wrong with urs. ur gonna need a new alternator just like me.
Old Jan 20, 2007 | 09:42 AM
antiricer's Avatar
Default Re: (EKris)
alright checked the dizzy and there was a problem with the wires, i cleaned the wires cause they were dirty and the car starts and runs, only thing is the car is ideling at 700, is that normal for sohc
Old Jan 20, 2007 | 02:52 PM
EKris's Avatar
o well thats good, atleast it wasnt anythin big and major. so thats good it runs, and about the IDLE at 700.. im not sure bout that one, never had a D series motor, so im not sure. but yeah man, its good to kno that u fixd ur problem. Take it eazy
Selena781
Apr 22, 2014 06:52 AM
wood181
Apr 15, 2008 06:59 PM
R-81DC2
Jun 5, 2007 09:21 AM
WAT THA!!!
Oct 8, 2004 01:08 PM
chadmasterc
Jul 29, 2003 02:11 PM
