found the leak!! but what is it?
Old Jan 19, 2007 | 09:22 PM
ahloung's Avatar
Default found the leak!! but what is it?
i found the spot that is leaking oil, but i dont know what it is. it doesn't constantly drip oil but it will drip a few drops every 12 hours or so.
Old Jan 19, 2007 | 10:14 PM
DucDucSTFU's Avatar
Default Re: found the leak!! but what is it? (ahloung)
oil pressure sensor
Old Jan 20, 2007 | 03:49 AM
InvaderTrax's Avatar
Also check to make sure the filter's tight
Old Jan 20, 2007 | 05:49 AM
sk8erdude1386's Avatar
If the leak is coming higher then the oil pressure switch and the filter is tight try to replace the oil cooler o-ring. It is the big o-ring that is between the block and the part where the oil filter srews on. I had the same problem on mine and I have seen it on many others.
Old Jan 20, 2007 | 08:10 AM
M2B4's Avatar
Default Re: found the leak!! but what is it? (sk8erdude1386)
has it always done it or just this oil change? easy stuff 1st check the filter.
Old Jan 20, 2007 | 08:16 AM
AdReNaLiN's Avatar
check filter isnt too tight too
Old Jan 20, 2007 | 08:51 AM
A Blue Lude's Avatar
Default Re: (AdReNaLiN)
Or that the old filter o-ring came off with the old filter and didn't get stuck on.
Old Jan 20, 2007 | 11:10 AM
preludefien
Guest
Posts: n/a
Default Re: (A Blue Lude)
dude if it the oil pressure sensor do NOT over tighten. i have seen many ppl crack the block from overtightening...its a pain in the *** to fix..check the o ring..im sure thats what it is..
Old Jan 20, 2007 | 11:13 AM
Lewdin' Incognito's Avatar
Default Re: (preludefien)
Oil pressure sensor. Mine did the same thing, got it for like $35 from Honda. Is easy to replace, don't let the shop do it. Dealership quoted me $95 dollars. Took me 15 minutes from jack to drop, just make sure you wrap plenty of teflon tape on the threads and don't get any tape on the front of the sensor.
Old Jan 20, 2007 | 11:19 AM
prelittlelude's Avatar
licke everyone said ususally this is the oring that leaks behind the oil cooler. either that or the oil filter is leaking. you need to feel around with you hand and see if there is oil up their. or wipe erything clean start the car and let the oil warm up and then let it sit so the oil will just drip strait down. if the oil cooler is leaking you can find out this way
acmoc
Dec 1, 2016 09:46 PM
DelsolVted
14
Mar 15, 2011 08:12 PM
christian7750
23
Mar 31, 2009 01:16 PM
TeGGY_LS
Aug 6, 2004 01:16 PM
degradated
Oct 29, 2001 07:32 PM
