just finished motor swap b18c5, but one prob!!!
Old Jan 19, 2007 | 03:48 PM
ilovejdmhoes23's Avatar
Default just finished motor swap b18c5, but one prob!!!
I just finshed swaping my motor in eg it looks real clean!!!! Pics soon to come, but there's one problem there's no fuel! Tried to start up and nothing. There's spark so I disconnected the fuel line a lil bit and nothing. I dnt hear the fuel pump turn on. So how can I check that? Is there a relay or fuse? I need to get my car out on the road. O yea and one more thing I sparyed some starter fluid in throttle body and I cranked up! Thanks I appreciate any info
Old Jan 19, 2007 | 03:54 PM
sicones's Avatar
Default Re: just finished motor swap b18c5, but one prob!!! (ilovejdmhoes23)
what ECU are you using, P73 OBD2B has an immobilizer that's will also keep your fuel pump from running (not sure about spark though)
Old Jan 19, 2007 | 03:55 PM
MasterKwan's Avatar
USDM? 2000-2001 ECU? If so then it's probably the immobilizer in the ECU. Jumper the main relay to power the fuel pump and see if it'll run. If so, then it's likely the immobilzer. You can run a JDM ECU, remove the immobilizer chip on the ECU or get and older USDM ECU.
Old Jan 19, 2007 | 03:56 PM
Default Re: just finished motor swap b18c5, but one prob!!! (sicones)
o its a 93 hatch with a p72 obd1 gsr
Old Jan 19, 2007 | 03:58 PM
JDM-EJ698's Avatar
It might be your main relay.check it.
Old Jan 19, 2007 | 04:10 PM
MasterKwan's Avatar
You look in the shop manual and follow the test procedure. You're using an adapter harness? If I remember correctly you might need to switch some wires over on the ECU harness.
Should be able to find that in the manual too.
boosted_fuzzy
Engine Management and Tuning
May 28, 2013 06:06 AM
no_rice_please
Oct 12, 2009 09:36 PM
krysted9354
20
Apr 8, 2009 03:32 PM
civic89si666
Mar 21, 2006 06:05 PM
b16a1sirhb
Apr 9, 2003 11:50 PM
