just finished motor swap b18c5, but one prob!!!
I just finshed swaping my motor in eg it looks real clean!!!! Pics soon to come, but there's one problem there's no fuel! Tried to start up and nothing. There's spark so I disconnected the fuel line a lil bit and nothing. I dnt hear the fuel pump turn on. So how can I check that? Is there a relay or fuse? I need to get my car out on the road. O yea and one more thing I sparyed some starter fluid in throttle body and I cranked up! Thanks I appreciate any info
Re: just finished motor swap b18c5, but one prob!!! (ilovejdmhoes23)
what ECU are you using, P73 OBD2B has an immobilizer that's will also keep your fuel pump from running (not sure about spark though)
USDM? 2000-2001 ECU? If so then it's probably the immobilizer in the ECU. Jumper the main relay to power the fuel pump and see if it'll run. If so, then it's likely the immobilzer. You can run a JDM ECU, remove the immobilizer chip on the ECU or get and older USDM ECU.
You look in the shop manual and follow the test procedure. You're using an adapter harness? If I remember correctly you might need to switch some wires over on the ECU harness.
Should be able to find that in the manual too.
krysted9354
20
04-08-2009 03:32 PM
