could this cause a tranny grind or issue?
Old Jan 19, 2007 | 03:26 PM
vtec4lyfe's Avatar
Default could this cause a tranny grind or issue?
My b series tranny has a slight 3rd gear and 5th gear grind. I am planning on getting all new syncros in the near future and i was wondering if this leak could cause my tranny to start to grind or for the clutch not to compress all the way? I am speaking about the black fluid leaking from the ball area.
Thanks in advance
Old Jan 19, 2007 | 03:28 PM
excivicboy96's Avatar
Default Re: could this cause a tranny grind or issue? (vtec4lyfe)
i have that same problem in my car its leaking grayish fluid. but i dont get any grinds unless its on my part.
Old Jan 19, 2007 | 03:31 PM
vtec4lyfe's Avatar
well my third gear grinds even if the clutch is compressed all the way and the shift is perfect. Could this leak in fluid be a sign of the master cylinder failing?
Old Jan 19, 2007 | 03:38 PM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: (vtec4lyfe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec4lyfe &raquo;</TD></TR><TR><TD CLASS="quote">Could this leak in fluid be a sign of the master cylinder failing?</TD></TR></TABLE>
could? IT is a sign that the master is failing. replace it.
Old Jan 19, 2007 | 05:00 PM
att1203's Avatar
You'll need to replace the clutch master cylinder. This will remedy your situation. I had the same problem.
Old Jan 19, 2007 | 05:04 PM
hondachris1994's Avatar
Default Re: could this cause a tranny grind or issue? (att1203)
I have the same problem, but I have no tranny grind issue...u need to replace your clutch master, but your still gonna have grinding issues g/l
young geezer
Mar 23, 2010 08:23 AM
BlackLudeSR
Jun 21, 2007 01:50 PM
chinaski
Nov 8, 2005 03:29 PM
Jimmy
21
Aug 13, 2005 08:45 PM
allmotor.net
May 23, 2004 08:53 PM
