tranny problems?
Old Nov 1, 2005 | 10:18 AM
chinaski's Avatar
Default tranny problems?
i started up my car today and i couldnt get it into gear once engine was running. when i did manage to get it into gear the car had a really low idle and was slowly moving forward and shaking when i took my foot off the break (and i wasnt on a hill). also shifting between gears felt clunky. i was thinking that maybe i was low on tranny fluid but that i dont think that explains why i couldnt get my car into gear and then it slowly moving forward and shaking. anyone got any ideas what the hell is wrong with my tranny?
Old Nov 1, 2005 | 01:31 PM
GSARR01's Avatar
Default Re: tranny problems? (GeeSeR96)
pressure plate maybe? or maybe your tranny is just going south on you
Old Nov 1, 2005 | 01:39 PM
TealEG!'s Avatar
did you check your master and slave cylinder. check for brake fluid under the clutch pedal and look behind the boot on the slave cylinder to see if it is leaking. also check the fluid in the clutch master cylinder reservoir. if any of those are leaking it would cause problems with shifting.
Old Nov 1, 2005 | 03:54 PM
Ninety3 Integra's Avatar
Check what GBPDC2 said.
Old Nov 1, 2005 | 08:28 PM
chinaski's Avatar
Default Re: tranny problems? (GBPDC2)
alright, so i just checked behind my clutch pedal and i did find, what i am assuming, is brake fluid. i recently had my clutch slave cylinder changed so i dont think that is leaking. but im having trouble getting the damn car in gear. anyone else have any opinions as well?
btw: thanks for the input
Old Nov 3, 2005 | 09:14 AM
TealEG!'s Avatar
well if you didnt have your master cylinder changed and you have brake fluid under your clutch pedal i would take a wild guess and say it is your master cylinder.
Old Nov 8, 2005 | 11:22 AM
chinaski's Avatar
well i checked everything i could from what you guys recommended, didnt find anything wrong so i took it to an acura/honda specialist mechanic and found that my clutch decided to die on me with no warning.
i thank you all for the input
Old Nov 8, 2005 | 03:29 PM
Dogginator's Avatar
Daisy... Daisy...
Your symptoms sounded like you needed to bleed the clutch slave cylinder. Your clutch wouldn't disengage, which doesn't indicate a bad clutch. A slipping clutch would be bad.
DeViuS
Feb 17, 2021 11:33 AM
young geezer
Mar 23, 2010 08:23 AM
vtec4lyfe
Jan 19, 2007 05:04 PM
allmotor.net
May 23, 2004 08:53 PM
Krayzielix
Dec 28, 2003 10:35 PM
