could this cause a tranny grind or issue?
My b series tranny has a slight 3rd gear and 5th gear grind. I am planning on getting all new syncros in the near future and i was wondering if this leak could cause my tranny to start to grind or for the clutch not to compress all the way? I am speaking about the black fluid leaking from the ball area.
Thanks in advance
well my third gear grinds even if the clutch is compressed all the way and the shift is perfect. Could this leak in fluid be a sign of the master cylinder failing?
I forgot more about hondas then you will ever know....
Location: hop,skip, and a jump from the city,, new friggin york, USA
1 Post
Re: (vtec4lyfe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec4lyfe »</TD></TR><TR><TD CLASS="quote">Could this leak in fluid be a sign of the master cylinder failing?</TD></TR></TABLE>
could? IT is a sign that the master is failing. replace it.
Re: could this cause a tranny grind or issue? (vtec4lyfe)
You'll need to replace the clutch master cylinder. This will remedy your situation. I had the same problem.
Re: could this cause a tranny grind or issue? (att1203)
I have the same problem, but I have no tranny grind issue...u need to replace your clutch master, but your still gonna have grinding issues g/l
Jimmy
21
08-13-2005 08:45 PM
allmotor.net
05-23-2004 08:53 PM
