y7 swaparoo
Old Jan 19, 2007 | 02:13 PM
fin781's Avatar
Default y7 swaparoo
when putting the d16y7 into 90 si body, using obd1 po5 ecu, is the d16a6 distributor and intake manifold interchangable to run the obd2 motor, i have an obd0 to obd1 conversion harness to take care of the ecu but do i have to buy a d16y7 wiring harness or can i just use my distributor?? help would be good thanks guys
Old Jan 19, 2007 | 02:18 PM
jlicrx's Avatar
Default Re: y7 swaparoo (fin781)
can't use the OBD0 distributor with the OBD1 ECU
Old Jan 19, 2007 | 02:30 PM
nihad's Avatar
Default Re: y7 swaparoo (jlicrx)
yes but need to re wire the distributor. not hard or buy a conver wire plug about 20 buck
Old Jan 19, 2007 | 02:34 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">can't use the OBD0 distributor with the OBD1 ECU</TD></TR></TABLE>
Yeah,,you need to get an obd1/2 distributor or an obd0 ecu.
If you wanted to, you could use your old si ecu,distributor and intake manifold and have the engine running fine..that's the cheapest way.
Old Jan 19, 2007 | 02:51 PM
fin781's Avatar
Default Re: y7 swaparoo (mr.speaker)
well i already have a chipped p05 (obd1) and the motor already has the obd2 distributor so like i could buy a conversion harness for the obd2 distribtor to the obd1 ecu ?? let me know i dont want to run into problems liek that other guy heh
Old Jan 19, 2007 | 09:16 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fin781 &raquo;</TD></TR><TR><TD CLASS="quote">well i already have a chipped p05 (obd1) and the motor already has the obd2 distributor so like i could buy a conversion harness for the obd2 distribtor to the obd1 ecu ?? let me know i dont want to run into problems liek that other guy heh </TD></TR></TABLE>
obd1/obd2 distributor is the same thing,it will work fine with the p05 you want to use.
7rrivera7
May 14, 2014 03:25 AM
dfanatic86
Mar 5, 2014 05:23 AM
TurboAngst
Dec 2, 2007 10:29 AM
Adam West
May 8, 2006 03:47 AM
Norcalstoppy
Jul 13, 2002 08:02 AM
