running on 3 cylinders
Old Jan 19, 2007 | 01:23 PM
xmonkiix's Avatar
Default running on 3 cylinders
94 civic
my second cylinder from the cam gear has no compression...i dont know what might be the problem...the car still runs and runs smooth....i check my injectors and harness and they were fine...also check my spark plugs and spark plugs wires and there are fine....so what can be the problem......
Old Jan 19, 2007 | 01:29 PM
Syndacate's Avatar
Default Re: running on 3 cylinders (xmonkiix)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xmonkiix &raquo;</TD></TR><TR><TD CLASS="quote">94 civic
my second cylinder from the cam gear has no compression...i dont know what might be the problem...the car still runs and runs smooth....i check my injectors and harness and they were fine...also check my spark plugs and spark plugs wires and there are fine....so what can be the problem......</TD></TR></TABLE>
Before you start getting people confused.
The cylinder you are referring to is cylinder #3, easier reference so pple know.
So you have absolutely NO compression and the car's running 100%?
Seems like you screwed the test up.
Are the spark plug threads screwed up at all?
SiBuddy00
16
Sep 10, 2015 01:59 AM
xmonkiix
Jan 19, 2007 02:22 PM
Streetracer4life128
Jul 2, 2006 03:12 PM
dc2typie
Sep 25, 2004 06:16 PM
FA Q RACING
Honda Motorcycles
Aug 25, 2003 08:02 AM
